Question about GE Dryers
Dryer making thumping noise when drying clothes and while running empty.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Mar 20, 2011
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
Thumping sound when drying?
change your belt or replace the spring that tensions the belt
Jul 13, 2017 | General Electric GE DBVH520EJWW Electric...
Dryer tub makes noise as it turns. 2000 model kitchenaid clothes dryer. noise occurs while drying. thumping sound.
heatman101
Aug 01, 2011 | KitchenAid Dryers
My kenmore gas dryer model 110-76662501 is making a thumping noise while the dryer is running. The dryer is about 5 years old used about 3 times a week. The clothes dry fine. Maybe a pulley or...
heatman101
Jul 11, 2011 | Kenmore Dryers
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Dryer makes a "thumping" sound even when it is running and clothes are not in it. Sounds like a pair of shoes are in there being dried.
heatman101
Oct 18, 2010 | LG DLE3777 Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
94 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
