I have a Whirlpool duet sport washer WFW8500SR00. I need to replace the bellows. I don't know how to get to the inside retainer belt. Help!
jsrock516
  • 5911 Answers
SOURCE: Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Posted on Sep 29, 2007
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
jsrock516
  • 5911 Answers
SOURCE: tear in bellows on whirlpool duet sport
If the model number you have this listed under is correct, then the following link will guide you through the necessary steps required to replace a door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I apologize, but I do not have any pictures to upload of the procedure. However, if you go to searspartsdirect.com and type in your model number, there are some excellent exploded view diagrams of your washer to assist in dis-assembly and repair. The bellow and components are listed under the "Door and Latch Parts" heading. The part number for door bellow is 8182119.
An alternate method of replacing the bellow is to remove the top panel of the washer and work through the door opening. However, the method described in the link provided, offers the best access.
If you have questions, if this is not your make and model number, or if you require additional assistance, please let me know.
PS Appliancepartspros.com has the door bellow for a better price.
Posted on Jan 21, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Hi, I have the same problem on my Whirlpool Duet GHW9100LQ1.
The following link explains how to replace the bellow on a Whirpool Duet:
The part number for the bellow is 8181850.
Searspartdirect.com carries it for about $81.
Appliancepartspros.com carries it for about $76.
Repairclinic.com carries it for $95.
Pcappliancerepair.com carries it for about $73.
Two other items you may also consider are the bellow clamps (if yours are damaged). The rear bellow clamp part number is 8182210. The front bellow clamp part number is 8182211.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 16, 2009
Whats the torque on the rear spin bearing on the outer hub on a whirlpool duet sport ht, model number WFW8500SR00, THANKS SO MUCH
i assume the bearing is connected to a belt drive. if so its more important to get the tension on the belt first , to prevent unesssecary wear on bearings,and i believe it would be the same tension that you would have on the alternator belt of a car.
May 23, 2012 | Whirlpool WFW8500SR
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Installing a bellows gasket onto duet sport whirlpool washer
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hw do I replae the washer bellow seal on a whirlpool duet washer
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
Replacement parts (if required) can be purchased at any of the following web sites:
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport WFW8300SW01
This is a pretty easy repair to do and all you need to do is open up the door and go around the outer lip of the bellows gasket and find the retaining loop that holds the front edge onto the front cabinet panel. Look for the locking loop and carefully remove it. I find that a couple of pairs of small needle nose pliers work well, just be careful not to bend the retaining wire loop, as you'll need to reuse this when you put the new bellows gasket on.
Here's a line drawing that shows your washer model and the parts involved, to help make this a bit easier to understand and so you can see what you're going to do.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR%20AND%20LATCH%20PARTS&documentId=W0607261&backToLink=Return%20to%20subcomponent%20list
Once you've got the outer lip retainer off, you'll be able to roll back the gasket off the front panel mounting lip and get to the rear hose clamp. It's basically a giant diameter hose clamp like you'd find on your car's radiator, etc. You'll need a small socket or nut driver to remove this clamp (usually it's either a 1/4" or 5/16" but sometimes it's a larger 3/8" size.
Loosen it and remove it carefully and you can now remove the entire bellows gasket.
When you go to install the new one, you'll want to make sure that you line up the water inlet section properly (if your's has this design, so do, some don't). Be careful not to rip or tear the gasket when putting it on the outer tub and when you tighten up the clamp. Take your time and don't rush this, as you don't want to be doing it again, as these gaskets aren't cheap!
Once you've got the rear of the gasket on, you can then carefully and gently start pulling the front lip onto and over the outer front cabinet. It helps to have help in holding the starting point onto the lip while you continue installing the rest of the bellows gasket onto the cabinet lip.
Once you've got the entire gasket on the front cabinet and you're sure it's on the lip all the way around the panel. You can then reinstall the retaining wire loop.
Now you're done and can give it a try, as you've just likely saved yourself about another $150-175 bill by not having to have a service tech come out and do the job for you!
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gasket replacement
The following link explains the steps required to replace the door bellow on a Whirlpool Duet:
Read through the link thoroughly. An alternate method is to remove the washer top panel and work from the top and through the door. The method I mention, offers the best unobstructed access. The placement of the wire hoop is mentioned in step 12. If you have questions, or require additional assistance please let me know.
Feb 09, 2009 | Whirlpool GHW9400 Front Load Washer
Tear in bellows on whirlpool duet sport
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bellows seal is not sitting properly and metal ring has fallen out
The following link explains how to replace a door bellow. Towards the end of the link, it explains how to reseat the wire retaining ring:
This is not a difficult repair. It can be a tedious, but you can accomplish this easily with a little help. I hope this helps you.
PS I hope you held onto the retaining ring. If not, you will need to order one. Searspartsdirect.com carries replacements.
Aug 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
NEED HELP
not hta tbad takes alittle patience and a third hand wont hurt either. theres aspring holding the front of the belllow in place peel it back slightly youll see it, pop the spring, and then theres a clamp holdin the bellow to the inner tub, youl find the relaesa (eitehr a phillips or possibly a 7/32 socket i beilieve) afeter releasin ghte clamp its a matter of working the new bellow around the same li[ the old came off of, it may take some time but aftger its all on just resecure the clamp.(oh yea before starting to refit-- the new one slide it over the water fill first. the tricky part and thord hand will be need trying to stretch the spring back pver the front lip
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
