Question about ViewSonic VA916 Monitor
Viewaonic VA916 my monitor goes black after computer is on for about 15 minutes. i can turn off the monitor and turn it back on after a short period of time and it will work again. I bought this monitor used. my old monitor did not do this. anyone have a solution?
  • 6,771 Answers
From your description it is a power supply inverter board issue, the cause is usually bad capacitors that sometimes puff at the top indicating they are open. In order to address the situation the unit must be dismantled in order replace the parts or board.
Posted on Mar 17, 2011
I have a VIew Sonic monitor VA916. When a sign on the monitor, the desktop is only few minutos and then the monitor is black. I can enter to menu. Can I reset the monitor?
Sorry to read about your problem, I hope this helps you out.
their is no reset for the monitor. you can try and take a monitor to a friends, and see if it does the same thing, this will help you tell if its the pc or monitor.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | ViewSonic VA916 Monitor
Monitor goes black immediately after waking from sleep, at the same time the power light changes from green to yellow. Image is just visible on black screen when viewed with a torch, After a wait of about...
Common problem in this model is bad DC filter caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 01, 2010 | HP Pavilion F1523 15" LCD Monitor
I have an hp w1907 monitor i start up puter and after about 15 miniuts the monitor goes black i turn the monitor off and about 5 minutes later i turn it back on and works fine for about another 15 minutes
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get parts from
www.lcdparts.net
Dec 13, 2009 | HP w1907 LCD Monitor
Polaroid 15" HD Widescreen LCD 1511-TLXB, turn on, stays on for about 30 seconds to 1 minute and then screen goes black, no sound, no menu
Do you have to turn it back on with the remote after this?
If so, then you may have set a timer by accident through the menu system.
More information would be required.
Aug 04, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Does not turn back on after switch off when warm
The monitor turns on, flickers and then goes black.
Dec 06, 2008 | Computers & Internet
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
ViewSonic VA916 Monitor Logo
63 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
