Question about Tripp Lite SMART PRO 1050 (smart 1050 rm) UPS System
Trying to put unit back together. Of the red and black leads from the power card, which goes to J3 and which goes to J5 of the control card. Also, the white lead from the main 60Hz input plug goes where?
  • 90 Answers
Http://www.tripplite.com/en/products/model.cfm?txtModelID=34 at the bottom of this page there are pdf files that may include the info you need. owers manuals etc. good luck!
Posted on Mar 17, 2011
How can i Recover Deleted Messages from Samsung Galaxy J5?
You can have a try of data recovery methods, I think that is a good choice for data recovery. Anyway, if you really want the deleted data back, you should try every possible method. Those recovery tools can also have the possibility torecover deleted data I think,
Recover Deleted SMS from Samsung Galaxy
May 08, 2017 | Samsung Cell Phones
I have a pioneer avic-n3(cpn213 and I dident have it in a car for a little while and when I went to put it back in it wouldent power up everthing was hooked up right with the red,yellow,and black and I get...
is the fuse in the back of the unit good? replace if blown. if not, get a continuity tester from local stereo shop or retail store (target/walmart/etc) for around 10 bucks. one lead goes on a good ground and the other lead to the red or yellow wire to check for power.
Jul 24, 2011 | Car Audio & Video
I got the bandit back in pieces and am trying to figure which lead goes to which spark plug. There are 2 "coils", each with a black and a red. One is a short and long lead. The other has two...
The coil with the short and long leads connects to cylinders 1 and 4. The similar length leads connect to cylinders 2 and 3. It does not matter which way round as the leads on each coil fire together.
Nov 12, 2010 | 1997 Suzuki GSF 250 Bandit
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I am trying to install a 42" ceiling suspended fan .. just making sure the blue(1) and black(2) wires go together and then the green goes to the bare ground wire coming from the box.
If you are not using a seperate switch to control the fan the blue and black go together and the white goes to white and the green goes to green. The blue wire is the fan power wire and the black is the light power wire if you are just using the switch on the fan to control the fan speed then the above configuration is the way it should be wired.
Jan 19, 2010 | Aloha Housewares (93645) Ceiling Fan
Ford f250 battery leads go where? engine wiring has been removed and I,m trying to piece it back together
you say battery leads, Red + Black --- Positive goes from starter to positive post on Battery, negative cable from battery goes to good engine ground on block and you will need a ground strap from engine to frame..
Nov 02, 2009 | 1985 Ford F 250
Dell NPS-210AB power supply starts up then shuts off
hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Jun 29, 2009 | Dell Power Supply 330 Watts nps-330cb...
Motor for my vulcan convection range was disconnected for moving by previous owner. There are 4 leads on motor, red and 2 black, and only one red lead (marked #1) still has label. The stove leads are still...
Red wires are usually the in and out for the centrifugal switch. the black wire that goes to the panel inside the motor is likely the 120 connection, the panel is the start switch for the start winding of the motor. This black wire should be connected to the 120 (from inside oven) and one of the red wires (three wires together). The other black wire of the motor should be connected to nuetral (you will have to determine which of the wires you have left coming from the oven is nuetral) the other red wire should be connected to the wire that feeds back into the oven for gas valve/thermostat controls (you may be able to trace this wire by hand to see if it goes to thermostat and gas valves). Hope this helps.
May 03, 2009 | Vulcan 36LC Gas Kitchen Range
Excel functions
Here's one way to do it. Your formulas would look like this:
B1:
=IF(OR(J1=1, J2=1, J3=1, J4=1, J5=1),1,0)
B2:
=IF(OR(J1=2, J2=2, J3=2, J4=2, J5=2),2,0)
B3:
=IF(OR(J1=3, J2=3, J3=3, J4=3, J5=3),3,0)
etc.
If you don't want the zeroes to display, format the cells with a custom number format--type: 0;-0;;@
Nov 14, 2007 | Computers & Internet
Tripp Lite SMART PRO 1050 (smart 1050 rm) UPS System Logo
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
