Question about Kenwood Audio Players & Recorders
Loving the HD tv...have noticed a problem with my surround sound though. My kenwood amp auto sense's dolby digital 5.1 and some BD do work in DD 5.1 but most don't. It says DD5.1 on the package and the alternate languages always come up in DD 5.1. But english versions seem to be in dolby tru surround and my amp auto switch's to 3 speaker stereo when I start the BD. When I switch to spanish or french the 5.1 comes on and I have surround sound fine. Have you seen this before and is there any fix short of spending alot more money?
  • perkman779 Mar 17, 2011
    the BD package has the dolby digital logo on it as well as the dolbytrusurround logo....and the amp is working fine with all othe source's switching to and from surround as it decodes the source signal. Why dont the Blue disks always use one or the othe...why doesn't the package say English track only in trusurround? And do newer surround amps sense both? Or will I have to choose one or the other and always have to guess as to wether or not I will have a form of surround sound with tonights movie
    Guru:
  • 276 Answers
Your A/V Receiver must have the decoders for the source on the BD and for the newest audio surround sound you should be using a HDMI cable to the A/V receiver because the SPDIF optical or digital coaxial cannot handle the Dolby TrueHD and other newest codecs. Probably you are getting the down-converted audio because of this.
Posted on Mar 17, 2011
Why can I not change the setting from pcm to dolby digital on my tv
You don't. You change the signal at the source device end, not the TV.
If you have connected a Blu-ray player or a games console, then set the device audio option to Bitstream. This will send a data stream to the TV that it will decode either as Dolby or DTS depending on the source signal format.
Dolby Digital is only an option for an external AV source connected via HDMI. That's the only way to get a Bitstream signal in to the TV. The TV's internal tuner is only capable of PCM audio. It's a DVB-T tuner (standard definition) rather than the DVB-T2 tuner needed for HD. Even then, only the HD channels are encoded in DD.
Iff your BD player or console is decoding to stereo PCM, then it's doing the same job as the TV. There's a small advantage with one of the audio processing modes in how it limits the dynamic range, but other than that PCM and DD will sound identical. This is especially the case with any TV that has no optical audio out, as in this case. The TV can't pass a DD signal out to an external audio system. So all sound is played via the internal speakers or headphone jack. It'll all sound the same, PCM or DD.
Oct 13, 2014 | Samsung Televison & Video
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
PROBLEM WITH DOLBY DIGITAL ON HARMAN KARDON AV225
Well it it might not. What exact model TV?
Your high-fidelity equipment should get TV-related audio from the same place the TV gets it - Cable, DVD, BD or Sat. A digital feed each of them will carry TRUE Dolby Digital audio. There is little sense in diluting TV-related audio through a TV and it's marginal audio electronics that are usually limited to analog stereo.
May 20, 2010 | Harman Kardon AVR 225 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Oct 28, 2009 | Audio Players & Recorders
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
129 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
