Question about iLike Music
I have an ILIKE band page but my songs wont play. it says Sorry, this playlist doesn't have any playable songs :-( Whats up with that?
Original xbox game wont play on xbox 360
There is sadly some of the original Xbox games that isn't playable for a reason I do not know.
http://support.xbox.com/en-US/games/xbox-games/play-original-games
^Here is a link where you can see all the playable xbox games that are playable on the Xbox 360. If you can't find your game here, you cannot play it on the Xbox 360, I am sorry.
Dec 31, 2012 | Marvel Nemesis: Rise Of The Imperfects for...
Hii.. i recently buy lava a10 but i m unable to add songs from my memory card to the audio player's plat list. tell me how can i do that?
Menu-Audio player--Playlists-Create playlist--Now create playlist as you want-Now select same playlist which you have created-Options-Add-Now if you want to add single song, please click on song name and song will be added-if you want to add multiple song, then select "Multi" option from left side of the bottom-Mark the multi songs -Now press "Done" from left side of the bottom-Now select the first option of "Play" to play songs of playlist.
Mayank Purohit
Jul 25, 2011 | Cell Phones
How do I copy a CD, playable on a CD player?
1. First make sure you have some blank CD-R's. 2. Put one in the drive and load iTunes. 3. Make a playlist and select the songs you want and add them to the playlist. 4. When you have the songs you want (no more then 70min worth) highlight the playlist by clicking it 5. Now press the iTunes File Menu and select burn playlist to DISC. 6. In the disk format make sure Audio CD is selected. 7. Press Burn.
You can now use this disk on a CD player.
Regards, Chris
Jul 01, 2011 | Apple 27" iMac 2.8GHz Quad-Core Intel Core...
Samsung YP-U3 mp3 - Can't get my songs to play in certain order
I've never seen a MP3 player that you can select the order in which multiple songs are played, unless you do it manually or only have the song you want to play on it.
I think your efforts will be in vane.  Sorry
Apr 12, 2009 | Samsung YP-U3JQB MP3 Player
Can't create playlists on my zen x fi
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
Nov 30, 2008 | Creative Labs ZEN SLEEK MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
2nd G - Nano: Music syncs from Itunes but not playable
click on the ipod on the left and go to music, also maybe creating new playlists might help??
Apr 22, 2008 | Apple iPod nano
MP3 Player plays only 25 songs, capacity 1GB (861 MB)
Seems like a big problems you got there...
I reccomened re-formatting your drive to fat32 (for windows users) and giving it a second try.
I had the saem trouble a while back with my iPod Video 60gb and noticed that it was storing huge amounts of data that wasnt meant to be there. After the reformat it all worked again.
You also sure its not a full drive? because my Q-Be used to say "file error" on a full drive (vista bug)
---Give reformatting a go though.
Nov 03, 2007 | Audio Players & Recorders
Songs When Selected Play Something Else & Songs that are missing altogether
Follow this link - it explains how to update your player's firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Hopefully this should solve the problem. if you need the user guide find it here; http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf I Hope this helps :)
Mar 11, 2007 | SanDisk Sansa e260 MP3 Player
iLike Music Logo
99 people viewed this question
Top iLike Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you an iLike Facebook App Expert? Answer questions, earn points and help others
