Question about Summer Infant Baby Care
Power lost to mobile unit, upon power up unable to receive signal. Camera is on, mobile unit says out of range and is fully charged. Thanks.
    Genius:
  • 1,622 Answers
Hi,you can use this troubleshooting tips to rectify the problem..
How to Troubleshoot a Summer Baby Monitor
Summer Infant baby monitors are some of the best reviewed monitors on the market today according to Consumer Reports, as well as individual parent reviews on various websites. But that doesn't mean they aren't without fault at times. Summer Infant produces various models of baby monitors, some that are strictly audio monitors, and others that are video and audio monitors. However, the steps to troubleshoot both types of monitors are the same.
things you'll need:
* Philips head screw driver
Instructions
Check the power charge on the unit. Whether you have a video and audio unit or audio-only monitor, the unit will need to be charged to work properly. If you have just purchased the unit, be sure to charge it for at least 4 hours before using it. You will be able to check the charge on the monitor with a "low-battery" icon on the unit. In some units, this will be indicated by a light - the light will be green for a "good" charge, yellow for a "low" charge and red for an "extremely low" charge or dead battery.
Check the rechargeable battery. If the unit does not seem to be holding its charge for very long, or not at all, the rechargeable battery may be bad. Typically, these rechargeable batteries last between 18 and 24 months. New ones can be purchased directly from Summer Infant, or through other retailers. To replace the rechargeable battery, simply unscrew the back cover of the receiver.
Move any cordless phones or other cordless products away from the unit. These frequencies can interfere with the way that the monitor operates. In addition, you may find that you are able to pick up audio or video from another monitor in another home. Try moving your monitor's location in your baby's room and away from these other devices.
Bring the monitor closer to the receiver. Typically, the range for these devices is between 350-650 feet depending on your model. However, the closer the units are together, the better the reception will be. But having them too close together (closer than 15 feet) may result in audio feedback.
Move the monitor closer to your baby. If you have a video monitor with night vision, the best video results will be if the monitor is 4 to 6 feet away from your child. If you have an audio-only monitor, moving it closer to your child will increase the clarity of the sound.
Hope it helps.
Posted on Mar 17, 2011
I am not getting gps signals
1) Check BAUD rate and PORT
2) Ensure battery is fully charged ( AC or via USB) prior to use.
3) ensure clear view of the sky
4) keep away from mobile phones or other electronic items
5 It could be damage to the SIIRF chip because you have it plugged into car power when starting engine.
Please rate my help++++Thanks for using FIXYA
Jun 08, 2010 | Tomtom ONE GPS Receiver
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
My n20 gps some times does not search for sat signals and seams to be unable to find signals
the most common reason for this is a low battery
ALWAYS fully charge the battery before the trip either by the USB or the AC charger.Car charger does not fully charge but maintains a level of power only
If you plug it in to car power and start engine you will damage both the battery and the SIIRF chip
Nov 27, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Can not get a valid gps signal
Cannot get a valid GPS signal=
not fully charged on AC charger
not right baud rate or port
antenna disconnected inside unit
Burned SIIRF chip ( from plugging in to car power when starting engine)
Try charging the unit fully first......
rare for antenna to become disconnecetd unless dropped or opened.
baudrate and port can often be found automatically in GPS settings
Burned Chip requires a full Motherboard replacement Might as well buy a new GPS cost exceeds value.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 07, 2009 | Tomtom GO GPS Receiver
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Recently when returning from a trip my C550 giving keptme the message "satellite unable to locate" (not the exact words) This went on for a week or more but suddenly started locating me from the satellite....
Low battery power is generally r4esponsible for loss of signal or low signal. Charge itr fully before use and plug into car power source ONLY AFTER staring the engine so as to avoid spike deamage. The car charger cannot fully charge the battery it is justn sufficient to maintain a level of charge . If the battery gets too low it cannot maintain a constant signal.
Jul 24, 2009 | Garmin StreetPilot c550 GPS Receiver
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
Shutter does not open
The camera does not gets opened on power on it seems that some gear has broken inside
Feb 27, 2008 | Samsung Digimax A400 Digital Camera
Baby Care Logo
1,313 people viewed this question
Top Summer Infant Baby Care Experts
masud
masud
Tom Chichester
Are you a Summer Infant Baby Care Expert? Answer questions, earn points and help others
