Question about Xerox Office Equipment & Supplies
My Xerox XRX-951L does not take in the laminator folder
2 Suggested Answers
SOURCE: the lamination paper is stuck.
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
Posted on Jan 15, 2009
Paper **** inside
Probably rolled itself around the rollers. Got to be real careful to not have any exposed inside surface (of the laminating pocket) showing since that coating is heat-activated and sticky.
Unplug it, wait for it to cool, flip it over and remove the screws holding it together.
If the laminating pocket is just physically wrapped around one of the rollers, it will come right out. Re-assemble and go back to work being careful not to put anything through that is the least bit curly.
If the laminating pocket is stuck to one of the rollers, just chuck the thing out and buy another one. The cost of parts and repairs will exceed the cost of a new unit. To remove the adhesive, one would have to disassemble the entire motorized assembly and then heat the "offended" roller to more than 180?F to get the adhesive to soften enough to scrape it off. Then, while it\'s still hot, one has to use a solvent matched to the adhesive to remove all remaining traces (\'cause if there is any left, it will just suck the next laminating sheet right around the roller and you\'re back where you started).
Remember:
- Use only laminating pockets for that brand (different models may have different temperature ratings). If the clerk says their laminating pockets are universal, ask the Clerk to guarantee in writing on his company\'s letterhead that they\'ll be responsible for any damage / repairs / replacement. They won\'t.
- Don\'t put anything that\'s curling through.
- Don\'t put anything through where part of the inside of the laminating pocket is exposed (because as it heats up it will stick to anything and everything it touches)!
Mar 05, 2014 | Xerox Staples XRX LM1910 Laminator
010-315 error code 4110 xerox
for solution go to http://xrx.sm/BJn
Jan 23, 2014 | Office Equipment & Supplies
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
Mar 14, 2011 | Xerox Staples XRX LM1910 Laminator
How do I obtain more Xerox return labels in order to return used toners? We're a central supply warehouse which receives used toners; the individuals who used the toners have not always saved the labels...
Hi!
Have you tried this option from Xerox?
Green Boxes, it seems like you order boxes for free from xerox to send back used toner cartridges.
This is the website:
http://www.xerox.com/perl-bin/product.pl?mode=recycling&referer=xrx/enus.html#
Take care!
Feb 28, 2011 | Office Equipment & Supplies
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
May 26, 2008 | Xerox Phaser 8500/DN Printer
Flashing 4h
http://www.xerox.com/xrx-search/MainSearchServlet?Xcntry=USA&Xlang=en_US&hostName=http%3A%2F%2Fwww.xerox.com%2F&gateway=%2Fgo%2Fxrx&searchString=H+codes&Search.x=0&Search.y=0&Search=Search http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR These 2 sites should guide you in the right direction. Good luck, Tim
Mar 06, 2007 | Xerox WorkCentre XD130DF Laser Printer
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
