Question about Proform XP 542S TREADMILL Drive Motor
I need to know how to change the drive motor belt on my Proform XP 542s. I have the new motor drive belt. I've marked the position of the bolt that holds the motor in place. How do I free the other end of the belt (by the front roller). Thank you.
  • 84 Answers
First you must mark the bolts that puts tension on the w/belt.then lossenthen almoct all the way . you need to relieve the tension on the w'belt. then remove the bolt that holds the front roller in place then the drive motor. slip off old installnew then tighten the front boltto wher you found it then with a little help move motor to oringinal spot tighten motor and then the back bolts
Posted on Mar 18, 2011
The belt is dragging and sticking...
hi if the belt is dragging and slipping when your standing on top that means you need a new belt, not the one you are standing on. the belt that is attached to the motor. if you start the treadmill and dont step on it i bet the belt runs smoothly. not that expensive to repalce under £20.00. hope i have helped
Nov 11, 2010 | Proform XP 542S TREADMILL Drive Motor
I have a pro form xp 542 s tread mill and think it is the speed sensor that is bad but i dont know where it is located or what it looks like,can u help me?
You have a bad mtr controller- did u leave the item plugged in wall without surge protector-did the power go off at house and then come back on(clocks blinking 12 one day)?? if yes to both you had a surge, if no still your controller/power board( all in one board) is bad
Jan 06, 2010 | Proform XP 542S TREADMILL Drive Motor
How to remove and replace a motor belt on proform
Hello there. To replace the drive belt (motor belt) follow this procedure.
1)Remove power to the machine
2)remove the hood cover (3 screws on the rear of the cover)
3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
Good Luck Tim
Dec 13, 2009 | Exercise & Fitness
Where is the speed sensor located?
owners manual will show this section, its under the mtr hood next to the frt roller pulley/mtr dr belt.
Nov 02, 2009 | Proform XP 542S TREADMILL Drive Motor
I have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Aug 26, 2009 | Exercise & Fitness
Incline on treadmill is acting strange
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
May 12, 2009 | Proform XP 542S TREADMILL Drive Motor
My new treadmill belt is to tight, motor won't run
i discovered a bolt protruduing about one inch just behind the drive belt from the moto to the roller. The drive belt had gotten over the bolt and that was causing the interfearence.
Apr 09, 2009 | Proform XP Weight Loss 620 Treadmill
Proform XP 542S TREADMILL Drive Motor Logo
162 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
