Question about Apple Multimedia Software Acoustica Mixcraft 4 for PC
When i play back my songs in mixcraft 4 it makes a pop and studdering noise
    Scholar:
  • 107 Answers
Try to play song on different music players like windows media player and if the studdering noise that you mention also occurs it means the problem is in your hardwares but if not and the noise only happens in mixcraft 4 then just re-install the software this should be able to fix the problem and if the noise is still there then you should go back to the store where you bought it and let them test it so that if the problem is in the cd you should be able to get a replacement
Posted on Mar 17, 2011
Code for acoustica mixcraft
look on or in the box we do not have codes
May 07, 2015 | Apple Multimedia Software Acoustica...
All audio is distorted or studders when playing
This could be an issue with the Primary IDE drive. It could be communicating in PIO when it should be in DMA.
Aug 11, 2009 | Acer Aspire One PC Notebook
2900 Keeps playing records
THE WURLITZER JUKEBOX WILL CONTINUE TO PLAY SONGS AS LONG AS ONE OR MORE, SELECTING PINS (THERE ARE 200 IN THE 2900 ONE FOR EACH SONG. THE PINS ARE IN LOWER SECTION OF THE CASE. BETWEEN THE SPEAKERS , AND LOWER DOOR.)
REMOVE LOWER BACK DOOR. WATCH THE ARM THAT STOPS ON THE NEXT RECORD, BECAUSE THE PIN IS UP. AFTER STOPPING ON THE PIN, THE ARM PUSHES THE PIN DOWN. THAT IS THE NORMAL OPERATION. IF THE PIN, IS NOT PUSHED DOWN, IT WILL PLAY THAT OR ANY OTHER SONG THAT HAS A PIN IS RAISED UP. THE PINS ARE THE MECHANICAL MEMORY FOR THAT JUKEBOX.
TURN OFF POWER, ==PUSH ALL PINS DOWN== THE SONGS WILL STOP PLAYING. THEN MAKE A SONG SELECTION. THE ONE PIN WILL POP UP THE MACHINE SHOULD PLAY THAT SONG.
WATCH THE ARM THAT STOPPED TO PLAY THE SONG, PUSH THE PIN DOWN. THAT IS THE SEQUENCE OF THE 2900 MACHINE,
WHAT CAN GO WRONG IS AS FOLLOWS. ==THE ARM DOES NOT PUSH PIN DOWN== THE ARM MISSES PIN== THE ARM NEED OIL, IT IS NOT LUBRICATED.==.
Mar 08, 2009 | Wurlitzer Jukebox CD Player
Itunes songs will not play
first be sure that the songs is existing in the same folder when you add it on the itunes library. if not you have to make another songs on your itunes library.
Feb 09, 2009 | Apple iTunes
Onkyo SR606 - Loud Poping
It could be a number of things,
1. an electrical short in the house. Try plugging it into another circuit with an extension cord.
2. A bad RCA cable that is input from one of your sources.
3. its probably a bad unit if you have Zone one and two playing at the same time the same source, but it only happens on zone 1.
4. a bad speaker can make a poping like sound, does it happen on all speakers? unplug all but one and one at a time try to determine if the problem sticks, if not, then one of the speakers is out of phase or blown.
5. Playing music froma computer source will sometimes make a pop if your computer is slow or bogged down with checking emails..etc. mine sometimes studders PPPPPPPrioRRRRRity CCCCCLLLLLLLLEEEEERRRRANCCCEE AAAAAAALLLLPPPPPHAAAA OOOOOOONE.
it also pops real loud when booting or shutting down.
Personal note ........windows is such a hassle for Media systems.
I hope something here helps!
Charles
Dec 31, 2008 | Onkyo TX-SR606 Receiver
Reinstalling new control panel in DELTA 246
Make sure all fragments of the original programme are uninstalled before installing a fresh driver.
Mar 09, 2017 | M-Audio Audiophile 2496 PCI Digital Audio...
Error free 4mb of space to build music library and disney mix max won't play any songs?
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 10, 2008 | Disney Mix Max Digital Media Player
New song
make sure the cords r plugged in properly. Then you can try to unscrew the 4 screws in the back and pop out the battery. make sure you put the battery in right and if that doesn't work download your songs from a different place.
Feb 22, 2008 | SanDisk Sansa e250 MP3 Player
Apple Multimedia Software Acoustica Mixcraft 4 for PC Logo
111 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
