I have a Haus WM 1050W washing machine with an error code seven flashes of door locked light. Can you help.
deeric27894
  • 167 Answers
SOURCE: machine is a Haus 1050w
Problem seems to be with sensors or with the PLC unit . Get it checked with Service Center Guys.
Posted on Nov 18, 2010
  • 6277 Answers
SOURCE: hi how do i remove
Sorry but I do not know your particular machine but here is my 'generic' document for symptoms of blocked softener tray, copied and pasted ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catch underneath or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover on it which you must remove to expose the little stuck up pipe/tube. This is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
I hope this is your problem and solution!
Good luck,
John C
Posted on Feb 14, 2011
  • 6277 Answers
SOURCE: Need instruction manual for Haus
(pre-typed!)
Sorry but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 19, 2011
  • 6277 Answers
SOURCE: Don`t have user instructions for Haus WM 1050W
Already answered on your later posting ;-0)
John C
  • 6277 Answers
SOURCE: I couldn't find the button
Methinks you could do with a manual for your washer- for now and probably later!
Unfortunately FixYa cannot do that for you direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
John C.
Posted on Sep 04, 2011
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
What is the error D3
I think that should be a "DE" error code. On LG machines the DE error code is for a "Door Open Error".
Check the condition of the door lock, door hook and switch as this will give the error code above, the switch can be checked with a multimeter for condition. You might need to replace the door hook or the internally mounted switch.
May 25, 2014 | LG WM-2077C Front Load Washer
I couldn't find the button to start machine Haus WM-1050w
Manual
John C.
Sep 04, 2011 | Washing Machines
Need instruction manual for Haus WM 1050w Washing Machine
(pre-typed!)
Manual
John C.
Aug 19, 2011 | Washing Machines
Just got a haus 1050w washing machine. it came with no manual so dont know what the symbals mean on the front help!!!
I am too looking for the same information. I know one is supposed to be half load but the symbols are still ambiguous it's difficult to determine which one!
Jul 12, 2010 | Washing Machines
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
