Question about Apple iPhone 3G
Cannot import contact from sim card to iphone 3G
Cannot import from sim card phone contacts to iphone 3G
  • 6 more comments
  • quazysonar Aug 21, 2008
    Yes, i put my old sim in just to copy the contacts and i hit the "import contacts to sim" selection but nothing happens. I can't believe they haven't offered an effective solution to importing contacts!
  • Anonymous Aug 26, 2008
    I have tried importing my contacts numerous times, and it is not working. O have looked at what is on my SIM card, and the contacts are their, but will not copy.
  • Anonymous Sep 02, 2008
    sim
  • Anonymous Sep 08, 2008
    same **** here, what do they expect to retype 245 contacts with names and address ? anyone has a solution for this ?
  • mjtourig Sep 11, 2008
    Same problem here - although the last time I tried it randomly imported 4 of about 60 contacts....
  • jamesmcg Sep 20, 2008
    I had a tmobile sidekick and I made sure to save the contacts to the sim. When I look on my old phone I can only see the sim contacts. But when I try to import sim contacts on my iphone it flashes up a notification for one second and then nothing happens. I've let long spans of time go by before I tap another key, but its just not processing them the from the sim.. any ideas?
  • SkyboltX Dec 17, 2008
    well... same as everyone else. it just flashes a notification and the nothing, not even some "random" imports as someone posted.
    nothing... and simport is nowhere to be found for 3g.
  • Anonymous Mar 21, 2014
    i like to change my sim
    New Friend:
  • 16 Answers
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Posted on Oct 01, 2008
The problem is, for whatever reason, the new iPhone firmware does not allow special characters to be imported onto the new phone.
So the only solution is to:
Get a different phone.
Put your SIM card into that phone.
Access your phone book from said phone.
Delete any contact using characters other that A-Z. This includes !@#$%^&*() And the like.
Once deleted just pop your SIM card back into your iPhone and import. It should now work.
Posted on Oct 10, 2009
Hey guys,
I bought iPhone from tesco and I had the same problem. I took tesco SIM out and put it in my old phone. Once sim was installed, I copied all my contacts in Tesco's SIM card. Once copied I removed the SIM card and put it back in iPhone.
And guess what? It worked!!!!!! hurray!!!!
Cheers
Saggy
Cheers
S
Posted on Feb 12, 2010
  • Stevensagaar Feb 12, 2010
    Hey guys,
    Cheers
    Saggy
Hi all. I have no idea why or how - but I was trying for hours to import from my t-mobile SIM to my new iPhone with no joy. I gave up and repaced my vodaphone SIM and pressed 'IMPORT SIM CONTACTS' for the heck of it.... and blow me down.... the flag came up saying it was importing and then all my contacts appeared!!! I have no idea why?! Hey ho! The wonders of technology!
Posted on Jan 16, 2010
I am having an identical problem to the original poster. I go to settings/contacts/import sim contacts and I briefly see a message that says "importing contacts from sim" but nothing happens.
The iTunes solution listed above doesn't work. It will present you with a "sim restricted" message. (It may work through iTunes if your phone is unlocked, but unless you're in Australia that's probably not the case.)
Also, DON'T try the solution listed above that says the iPhone only recognises A-Z characters. I just went through the sim contacts (whilst it was plugged into my old phone) and removed all non A-Z characters. For nothing. It still doesn't work.
I'm stumped with this now.... Very annoying. About to manually re-enter 200+ numbers :(
Posted on Jan 05, 2010
How to open the 3G iPhone or where to find the info
Posted on Sep 25, 2008
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
IPhone doesn't store contacts on the SIM card. If you want to transfer contacts between iPhones, you can use iCloud to backup or transfer content between devices. When it comes to import contacts from SIM card to iPhone, users will only need simple steps.
  1. Remove the SIM card from the old phone, and install it on your iPhone.
  2. Your iPhone may need to reactivate. If so, connect to iTunes.
  3. Tap Settings > Mail, Contacts, Calendars > Import SIM Contacts.
  4. Wait for the import to complete.
  5. If you swapped SIM cards in step 1, remove the SIM card and replace it with your iPhone SIM card.
  6. Open Contacts and make sure that the contacts imported.
Cannot import  contact from sim card to iphone 3G - cannot-import-contact-from-sim-card-oxaxc0rwhkhzilrwacqreyis-3-0.jpg The contact information imported from a SIM card depends on how your previous phone stored information on the SIM card. For more help with importing contacts from a non-Apple phone, check the manufacturer's website, app store, or contact your carrier.After doing this, you will get the contacts in your iPhone.
http://www.leawo.org/tutorial/how-to-transfer-contacts-from-sim-card-to-iphone.html
Posted on Jun 28, 2016
  • 4 Answers
What I did is used my old iPhone where my contacts were saved initially. Transferred the contacts from my old iPhone to my PC in the form of vCards via using this tool.
Next, imported the contacts to my new iPhone as per the video below:
This helped me put the contacts to my new iPhone.
Posted on Sep 20, 2012
Here's how I solved this: My old sim with my contacts was Fido. My new sim was Rogers.
1. I took out all sims, then turned off phone.
2. Inserted Rogers sim, then turned on phone.
3. While phone is on, I took out Rogers sim and inserted Fido sim.
4. Tapped Import sim Contacts, and it finally worked.
My itunes was giving me warnings whenever I inserted the Fido sim except when I did it this way. Good luck! I know how frustrating this can be.
Posted on Jul 05, 2012
Connect the iphone to itunes and the use sync the contacts from the sim card to the phone
Posted on Oct 13, 2008
Yup works for me tooo :)
Posted on Sep 05, 2008
I tried it and it does work. Are you sure you've copied your contacts from the old phone memory to the SIM?
Posted on Aug 23, 2008
Markyuk whatis vodaphone SIM?
Posted on Feb 19, 2010
Transfer contcs from a blackberry curve9350 to apple 3gs
u cant transfer it directly but u can transfer them to outlook and when u connect ur iphone to the pc u can choose to sync the contacts with outlook.
good luck
Feb 14, 2013 | Apple iPhone 3G
How do I copy contacts from my old sim onto my Iphone 3G S
Make sure you have a sim card on your iPhone then just go to Settings > Mail, Contacts, Calendars then scroll down until you see the option Import Sim Contacts and click on it to copy all your contacts to your iPhone
Jan 31, 2011 | Apple iPhone 3G
I want to copy my sim contacts on my apple i phone 3 g, but am unable to do so... i went to setting from their i imported the sim contacts but that is also not functioning.. it imports but in contacts...
This type of errors occur when you jailbreak your set, if you want to copy your contacts from the sim try with another Sim in your phone, if it gives error with all Sims, then you can copy your contacts in the Outlook and then synchronize your contacts with iPhone,
To copy your contacts to outlook, take any nokia phone capable of connecting with usb to computer and nokia pc suite, make your contacts syncronize with outlook firstly from nokia,
when you got your contacts in outlook , connect your iphone 3g with computer, and itunes will show you your set, then go to info and sync contacts with outlook, click on apply and then sync, all of your contacts will be sync and you will see the contacts in iphone,
If you require more assistance regarding this, feel free to reply to this post
Regards, BA
Jan 16, 2011 | Apple iPhone 3G
How to copy contacts from sim to iphone
As long as your contacts are saved to your sim then
1- go to settings
2- select mail, contact & calendars
3 - scroll down to import sim contacts
and voila! your contacts will get transferred over :)
Hope this helps!
(Please Leave Feedback )
Jan 06, 2011 | Apple iPhone 3G
Not showing contacts
Settings
Scroll down until you see "Import SIM Contacts"
Click it
Jun 28, 2010 | Apple iPhone 3G
I am not able to copy the contacts from sim card to my iphone
Aug 07, 2009 | Apple iPhone 3G
CANT IMPORT SIM CONTACTS AFTER IPHONE 3.0 SOFTWARE UPDATE
Jul 25, 2009 | Cell Phones
Move contacts from Tungsten E2 to iPhone
If the Tungsten has a SIM card you can save the contacts to that, put that in the iPhone and go to Settings>Mail, Contacts, Calendars> Import SIM Contacts. If that isn't a option you may be able to export as VCards and import them into Address Book if you use a Mac. I'm not familiar with a way to do this on a PC. Anyone else have a solution?
Oct 23, 2008 | Apple iPhone Smartphone
Import contact
Power cycle the phone first as sometimes it has problems finding the sim contacts if you insert a sim while the phone is already on. Then:Settings>Mail, Contacts, Calendars>Import Sim Contacts (near the bottom)
Sep 30, 2008 | Apple iPhone 3G
Can't read sim contacts
hi,i just restore my iphone,and next thing it can,t switch on,iphone couldn,t recognise my sim card and it shows only emergency and itunes sign in iphone.please help.
Dec 05, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
22,554 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
