Question about Ovens
I have a C900SS savoir-faire oven but the previous owners did not leave the oven manual. I am doing my best at guessing at the correct settings but would really appreciate a manual to refer to. Regards Kim
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
  • 1314 Answers
SOURCE: Frigidare double convection self-cleaning oven
try here kim if you dont find what you need contact me back http://www.frigidaire.com/support/manuals.asp
Posted on Jan 29, 2009
SOURCE: lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Posted on Oct 16, 2009
damnor01
  • 1179 Answers
SOURCE: I have moved into a home that has a Modena oven.
I think it's the thermostat.
The thermostat turns the oven on until it reaches a desired temperature, then once the temperature is reached it turns the oven element off thus allowing the dish to slowly heat up. Which in turn gives you a well cooked, middle included, dish.
I would say the thermostat needs to be replaced, it should not cost a whole lot. You may need to get it installed though.
Take care and Happy Cooking!
damnor01
Posted on May 26, 2011
  • 360 Answers
SOURCE: I'm the new house owner & there's no manual for
Download the manual from the following link. http://dl.owneriq.net/d/d9667099-caed-48b2-8424-f0d91139a9ec.pdf or go to following link http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html
Both are same links.
Posted on Aug 30, 2011
How do I fix my programing light on my oven fix my
the programming light ???
on what model what make
this is a display ilumination ????
if so its usually a small 12V bulb or in some a led backlight
sometimes there is a button too turn it off
call an engineer in the fix it or ask a pal with electronics knowlage
as you dont seem very confident too do it leave it too someone who knows how to use a multimeter and get the right part
quite easy a service tech should charge you know more than £40
+ parts
Nov 30, 2014 | Ovens
Savoirfaire oven
I have used Repair Clinic.com in the past and have found it to be helpful in fixing wall oven.
Jul 14, 2014 | AEG Ovens
Oven does not work
Check the fuse, if this OK, replace the heating element
Mar 26, 2013 | Ovens
Need a manual for 667
www.apdepot.com
Apr 23, 2012 | Ovens
Oven won't come on?
Check that the timer is set correctly as often owners don't set them right; I'm guessing you changed the element without turning off the breaker. If this is an oven with a digital display, turn the breaker off and back on, this might reset the board.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Ovens
I need opperating manual for a Savoir Fair oven model # W 600 Black
Thank you for choosing FixYa today for your online technical support needs.
Unfortunately I have been unable to locate any online resources pertaining to that particular model of Savoir Fair appliance. As such, I am unable to provide you with the instruction manual / documentation you requested. I'm afraid your only recourse is to contact your local dealer where you purchased the unit and see if they can get you a hard copy of that manual since that information is simply not available anywhere online.
Seeing as I did not provide the information you requested, you are welcome to request a refund of your service fee. Simply leave the the service unrated and then click on the REQUEST A REFUND button when you see it. Your purchase fee will then be refunded automatically to your credit card.
I apologize again for not be able to help you with this request, but sometimes information on the lesser known brands is simply not made available on the internet, unlike mostt of the major name brands which are usually well supported online.
Thank you again for your patronage, I hope that we can assist you better next time.
Good luck and take care.
Joe.
Nov 23, 2011 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Burners light ok, oven will not light
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Ovens Logo
860 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
