Question about Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C
I have apoulan pro prrt850 17 inch rear tine tiller. When I took it out of storage, it started great but I could not engage the tines. The lever that moves the transmission into forward, till, or reverse is stuck. Took it to a trusted repair shop and they said problem is that water got into gear box and froze it up. They want $400 to fix, which is about as much as I paid. Any suggestions on alternatives??
    President:
  • Poulan Master
  • 1,545 Answers
If the gearbox has a fill plug, remove and let it air-dry or blow compressed air into it to help dry. Then, get some PB Blaster aerosol penetrant/lubricant from the auto parts store and spray as much as you can ito the box. Let is soak 24 hours or so and THEN come back to it and see if you can get it unfrozen.
Posted on Mar 17, 2011
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
The tiller won't stay in gear for the tines to turn. It jumps into forward without turning the tines.
Check the wire to make sure that when you engage the tines it is actually engaging the lever. This seems like your are either low on the fluid for the trans or it is stuck in place and will need some good lubrication and turned by hand. You can also with the engine off, engage the tines, and try to turn it by hand. if it turns by hand then the tarns is no good.
Nov 09, 2010 | Yard Machines 21A240M000 Garden Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C Logo
471 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
