Question about Maytag M3DH30B2A Dehumidifier
The dehumifier is running but it isn't taking water from the air. The bucket is empty. Maytag dehumifier Model #m3dh30b2a serial #as750118
    Brigadier General:
  • 4,736 Answers
The operation a dehumidifier is based on the amount of humidity, the house or room where you have it placed. If the humid level is low and you have the humidifier set on a low extraction setting, there would be little to no water in the bucket. However, if you have all the settings correct and you still don't get water in the bucket, the top 2 reasons for this are: The Filter needs cleaning and # 2 the drain tube or hole is clogged. The solution for cleaning the filter is a no brainer. The solution for unclogging the drain tube or hole is not that difficult. You will need a 12" to 20" long Plastic Zip Tie (or something similar, but no wire coat hangers), that's small enough to go through the drain tube or hole. When you remove the bucket look up and into the compartment that the bucket came out of and you will see the drain tube or drain hole. Slowly and carefully push the zip tie into the hole and continue to work it into the hole until you reach the curve in the tubing. This is the tricky part. Carefully and gently work it past the curve and about 4" more. Then start removing the Zip Tie as you slowly rotate it. This will dislodge any clogs. As you continue to pull it out, be prepared for water to follow it. If you have water draining out, your problem is solved.
If none of the above solved your problem, the condenser unit may be low on refrigerant. In which case, you will need a pro to service it.
Hope this information helps to solve the problem.
Posted on Mar 18, 2011
My M3DH30B2A dehumidifier only runs and does not absorb any moisture from the air. What can I do:?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 22, 2011 | Maytag M3DH30B2A Dehumidifier
Compressor and fan are running. no water collected from air.
heatman101
May 30, 2011 | Maytag M3DH30B2A Dehumidifier
Hi, i have maytag m3dh30b2a dehumidifier,its work but does not collect water
heatman101
Apr 22, 2011 | Maytag M3DH30B2A Dehumidifier
I plug in the dehumidifier, and all the operating lights go on, but it does not ever start working, no matter what I do with the settings. The water tank is empty, so it couldn't be that. Please help! ...
heatman101
Mar 15, 2011 | Maytag M3DH30B2A Dehumidifier
My Maytag 45 pint model M7DH45B2A dehumidier stops working before the bucket is full. The bucket is around 20-30% full, the dehumifier will stop as if the bucket if full. I empty the bucket and reseat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 25, 2010 | Maytag M7DH45B2A Dehumidifier
No moisture
check to see if the coils in the back are cold. if they are not, you either have no freon or the vent in the front is blocked and the condenser coils have no air flow to cool down. if they are, there might not be sufficient air flow across the evaporator coils or the air is already dry.
also, if the bucket switch isn't activated (due to the bucket not being in all the way), the fans will come on, but not the compressor.
Aug 12, 2009 | Maytag M3DH30B2A Dehumidifier
Will run but won't take moisture out of the air
Fedders, the maker of the maytag dehumidifier, went bankrupt and they are not honoring the warranties. call this number and if it is still under warranty, they will send you a prorated check for the remainder of your warranty. 1-866-629-8241. we had two months to go on our warranty and they gave us $14 and change.
Jun 01, 2009 | Maytag M3DH30B2A Dehumidifier
It sounds as if the fan motor is running, but the compressor is not.
Apr 05, 2009 | Maytag M3DH30B2A Dehumidifier
No water being removed-maytag dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Dec 02, 2008 | Maytag M3DH30B2A Dehumidifier
Empty tank, but "filled" light still on. Won't turn off
be sure that you all have the bucket fully installed against the bucket switch, to see if the switch is bad, remove the bucket and press in on the switch, if the compressor starts then the bucket is out of place if it does not start then the bucket switch needs inspection
Mar 20, 2008 | Maytag M3DH30B2A Dehumidifier
Maytag M3DH30B2A Dehumidifier Logo
338 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
