Question about Garden
Mig 180 en-welder has no amperage-wire feed is working ,gas is working fan is working, welder made wierd groaning noise& then shot out a spark from rh side of case- dosenot make any difference which power setting - high or low] it is on wire just mets in to a bb
  • 5,603 Answers
There has been a failure in the inverter. You will have to have the unit serviced and blown components replaced.
Posted on Mar 18, 2011
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
I have the lincoln 180 my wire is being fed but not getting any spark any ideas?
First make sure you have a good ground clamp and the line well tight to the machine. This problem is a common one.
Jan 07, 2011 | Lincoln Electric Lincoln Easy MIG 180...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
I need to know what size wire and plug to use on my clarke 220 volt welder model 160 en how many amps does it pull? what amp breaker do i need?what size wire do i need? the site will only let me post it as...
I would run a 10 AWG wire from the breaker to the outlet, if that is what you are asking. I have the same welder works great just wish I could find a spare wire roller.
Sep 11, 2009 | Clarke Power Products Mig/Fluxcore 180En...
Mig welding 1/16 thick metal
you should run power between 160-180 to get a godd weld with out burning your work
Jul 01, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Mig Welder problem
Has the duty cycle been exceded? if so the control chip will shut it off.
Oct 25, 2008 | Computers & Internet
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
