Question about Uniden Cordless Phone
Hi How ldo I set the # of rings on my phone Model# EXP4240
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
The EXP4240 isn't an answering machine. It will continue to ring until the caller hangs up or some other answering machine, fax, or voicemail system picks up.
Posted on May 28, 2012
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
PHONE DOES NOT RING
This might be due to the settings....
Ringer settings
To change the ring type and ring tone
1.
On the Phone screen, tap Menu > Options > Phone tab.
2. In the Ring type list, choose whether to be notified of incoming calls by a ring, a vibration, or a combination of both.
3. In the Ring tone list, tap the sound you want to use
You can find more information at the manual located at the below location.
http://www.htc.com/support/pdf/htctouchdual/NIKE_HTC_English_Manual_16-KEY.pdf
Refer the pages 33 & 83
I hope it will resolve your problem...
With Regards,
TPV
Feb 03, 2008 | HTC TYTN GSM Phone
Hi, I have a Cordles phone Uniden 6.0 Model: DECT1588-ST. Problem: The call gets automatically attended, after 6 rings at the max. Since the Number of Rings can be set to a maximum of only 6...
Hi
owners manual page 46 how to turn answer on/off
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/DECT1588om.pdf
Sep 07, 2017 | Uniden CEZAI998 Phone
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
HI,My land line phone doesn't ring
They all have a switch or a setting to mute the ringer Tom.
Google
make model manual
They are all online.
Feb 18, 2018 | British Telecom Synergy 2110 Cordless...
Got shocked by the tv as i touched it and wont turn on ever since...
you should call them and explain the shock from the tv that you got and if there is a recall on these models as well as the 26" that has power issues and can cause a fire or if you can get an extended warranty or what can they do for you to resolve this issue with your tv that they seem to be having with their other tv's also ( health hazzards! )
their main number is : 877-467-4289
or e-mail them here : http://www.insignia-products.com/EmailForm.aspx
Apr 30, 2009 | Insignia 37" LCD Flat-Panel HDTV
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
? how to set the # of rings
there is a ring select button on bottom of phone base. can be 2 or 5 rings
Nov 06, 2007 | GE 26998GE1 Cordless Phone
Uniden Cordless Phone Logo
52 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
