My panasonic sa ht670 is powered on but after a certain volume the sounds shuts off but power stays on. whats wrong?
  • 604 Answers
You are causing the fuse circuit to kick in by overloading the speakers. if you want more volume,, but some powered speakers
Posted on Mar 17, 2011
Panasonic SA-DM3 shutting down issue
The amplifier is over heating. Probably the emitters, drivers and voltage regulator is bad. I suggest a clean sweep replacing the power pack integrated amp, all emitters, mosfet regulator, and SRC power switch start up control.
Feb 08, 2014 | Panasonic Audio Players & Recorders
Panasonic SA-DM3 shutting down problem
You should check all your connections to your speakers. Also check each speaker to make certain there are no shorts in them. Check all speaker wiring for shorts too.
If it continues to play up, then a overheating fault will probably be traced to the power amp section. With something getting so hot that it will need to be replaced.
Sep 26, 2017 | Panasonic Audio Players & Recorders
I have a Panasonic HT-692 surround sound system. Any time I use the surround sound features and turn the volume to a higher level(not ear piercing mind you) the system cuts off as if a ckt breaker has
If you are playing the unit that loud, for an extended time it sounds like the unit is going into overload, meaning it's getting to hot. Try turning the volume down to 1/2 of your current level. If it stays running, you will have to cut back on your volume, before you seriously damage the unit(or your hearing)
Dec 18, 2011 | Panasonic Audio Players & Recorders
My dvd player is dead on my sa ht670 panasonic dvd player home theater. Is there any way to still use the other functions like aux? i do no need the dvd player just want to use the theater for sound. I...
Maybe if you ask it to OPEN the tray as soon as you turn it on and leave it that way it might move on to other functions. A hands-on tech would have to lay hands and eyes on it otherwise.
Jul 04, 2011 | Panasonic SC-HT670 System
I am having problems with my SA-HT670 it is reading error code INIT and then WAIT. The 5 disc changer will no open and close properly
The CD loading mechanism is not resetting properly. When powered on, the entire mechanism goes through a startup alignment sequence. This is to be sure that the unit is in a known position and state. The init indication is for the "electonics" reset portion, the wait message should be present while you hear the mechanism move. The most common cause of this is a slipping belt or a jammed CD. Be cautious about trying to repair this yourself. It is easy to damage the gearing inside or to get it out of aligment. There is a good possibility that this can be repaired with either no parts or with a $3-$5 belt.
Dan
Nov 02, 2010 | Panasonic SC-HT670 System
Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Feb 03, 2010 | Panasonic SC-HT500 System
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Panasonic dvd home theatre SA-HT670
my reciver is stuck on the cd changer so i can't change cd and it doesn't work only apear in the screen "wait" what can i do to fix the problem
Jun 02, 2007 | Panasonic SC-HT670 System
105 people viewed this question
 Grubhead
Grubhead
