Question about Canon PIXMA MX310 All-In-One Printer
My black ink cartridge was low so I changed it and then it only printed light blue. I exchanged the cartridge and now it doesn't print at all.
SOURCE: black not printing
same here id been surfing the net looking for an answer to this problem for 2 hours and i tried this and it worked waheyyyyyyyyyyyy
Posted on Sep 19, 2007
  • 49 Answers
SOURCE: Faulty Ink Cartridge?
You can try this, but maybe a new print head is needed.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
SOURCE: reset Ink levels for canon mx310
canon printer are very little number of print if you printing best photo
Posted on Aug 06, 2008
worldvet
  • 859 Answers
SOURCE: mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Posted on Nov 23, 2008
  • 291 Answers
SOURCE: Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Posted on Apr 03, 2009
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Changed cartidges & now black and blue don't print on C88+
Try to remove and reinstall the blue and black cartridge and check if you punctured the plastic cap underneath the cartridge itself. then reinstall it and make sure you hear a click or it snaps in. try head cleaning cycle from the utility and print a nozzle check pattern. If same output maybe carts are bad. If that is a genuine epson ink cartridge, call epson and have the ink cartridges replace since they are new ones and for sure epson will send inks since you just bought it. make sure you have date of purchase handy.
pls dont 4get to rate solution if it helps... thanks!!
Apr 16, 2008 | Epson Stylus C88 InkJet Photo Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
128 people viewed this question
old marine
old marine
