Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
We just purchashed a Frgidaire Freezer model #LFFH21F7HWG. Does it have leveling legs on the back as well as the front? Are we missing 2 leveling legs?
  • 604 Answers
Usually the back wheels are rollers that allow you to pull the fridge straight out from the wall, so NO, not leveling in the back, but you don't need it anyway, just use the front adjustments
Posted on Mar 17, 2011
I have problem turning leveling legs on upright Danby freezer
Get a block,then lift freezer and push block under with foot,then get a pair of plyers and turn legs,or get a 2x4 and do front,then back.get a leveler to see if it's level.
Aug 26, 2016 | Danby Freezers
Let's try this again. My frigidaire freezer model Lffh21f7hwg, the display board reads "of". How do I reset it. I do not have the owners manual.
I appreciate your post, Clayton!
From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
Mar 31, 2015 | Frigidaire Freezers
UPRIGHT FRIGIDAIRE (ELECTROLUX) FREEZER HAS STOPPED WORKING. LFFH21F7HWG
Hello Friend, I am happy to assist you!
I see that your Frigidaire freezer (LFFH21F7HWG) is not working. Often this is because it could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning your refrigerator out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in your appliance. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Best regards! - Z
Jul 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Figidaire model lffh21f7hwg lost manual don't know how to set digit inst. to set temp.
Free Frigidaire Freezer User Manuals ManualsOnline com Try this website. I know it is discontinued, but the manufacturer will be able to email you something.
Mar 16, 2014 | Freezers
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge is not level - it is higher at the front than at the back.
We had the same problem when our was delivered last week. I spoke to Samsung customer services.
They said the roller in the middle of the front is not meant to be there permanently. It is just a transport roller and should be removed once your fridge freezer is in place.
To remove it:-
- unscrew the two white plastic feet at either side of the front until they touch the floor.
- then place a flat end screwdriver in the slots in the feet and continue to unscrew them. They will start to lift the front of the firdge -freezer up until the front roller no longer touches the floor.
-keep doing this (a little bit each side at a time so the fridge -freezer stays level) until the roller is about 15mm off the floor.
- then get a small flat spanner and remove the two small bolts on the metal plate that holds the roller to the bottom of the fridge-freezer.
Once these bolts are removed the roller and plate will drop to the floor and can be removed.
Then using the screwdriver, screw the feet back in until the point when the front of the fridge-freezer is level with the back.
The whole process shouldn't take you longer than 15 minutes.
I asked Samsung why this isn't included in their instruction manual and they couldn't give me an answer which I thought was poor.
I do wonder how many Samsung RSH1 fridge-freezers are out there with the front roller still attached!!!
Oct 25, 2008 | Freezers
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
361 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
