Question about Detecto Model 6855 Bariatric Scale
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
  • 604 Answers
You need to turn the calibration setting to 100 lbs, then it will be calibrated
Posted on Mar 17, 2011
  • Declan Sebastian
    Declan Sebastian Feb 17, 2014
    and if that's all you do and think that's all there is to it you don't know anything about scales.
Whats a 2006 petrol v8 landcruiser 100 series weigh ?
weight specifications
Unladen Weight 4949.4 lbs OR 2245 kg Gross Weight Limit 7187.1 lbs OR 3260 kg
TOYOTA Land Cruiser 100 specs 2002 2003 2004 2005 2006 2007
Jan 16, 2018 | Cars & Trucks
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
How do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Mar 08, 2009 | Nintendo Wii Fit for Wii
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Detecto Model 6855 Bariatric Scale Logo
413 people viewed this question
Top Detecto Health & Beauty Experts
Louis Smith
Rhonda Webster
Rhonda Webster
swetha
swetha
Are you a Detecto Health and Beauty Expert? Answer questions, earn points and help others
