Question about Maytag MZD2766GES Side by Side Refrigerator
Ice in icemaker is melting. refigerator is making buzzing sound for several seconds at a time like a faulty switch that is having a hard time making contact.
    Guru:
  • 683 Answers
It sounds like the compressor is the problem.
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Posted on Mar 17, 2011
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
Icemaker on LG LFD25860ST not working.
Sounds like the hot gas defrost solenoid is enegised. the contoller for this may be at fault.
Apr 17, 2010 | Refrigerators
My sub-zero 532 makes ice that melts and refreezes
Hopefully, you've solved your problem by now, over a year later. If not, a similar problem I have with my 532 is due to the aluminum tube that the water flows through to fill the icemaker. Over time, this metal tube moves away from the icemaker toward the hose it is attached to due to the hose being warmer than the freezer compartment. This creates a gap between the metal tube and the icemaker causing water to spill into the ice bucket each time the icemaker refills. It makes you think the ice is melting and refreezing, but it is really just the water freezing when it spills into the ice. To correct the problem. you have to remove the icemaker, which is not that difficult, if you have a long stem phillips screwdriver. Then grab the metal water tube with some needle nose pliers, and pull it toward you to return it to its original position. If you pull too hard and it comes completely off the hose it is attached to, it is difficult to re-connect, but can be done, as I have had this happen several times, and have succeeded to re-connect it each time with some patience. The metal tube must fit snuggly into the icemaker when the icemaker is re-installed to prevent it from leaking water into the ice bucket each time it refills. My model 532 is now 23 years old and still working. Good luck!
Sep 10, 2009 | Refrigerators
Recurring buzzing sound with icemaker
The buzzing sound may be the sounf of the electric water valve (Solenoid) when filling ice cube tray.
Aug 31, 2009 | Jenn-Air JCD2389G Side by Side...
Ice maker does not work. Has worked fine until about a week ago
Mine has done this several times. There is a switch, usually in the tray above the ice container at the back. Move the switch to the OFF position for about 30 seconds. Now, turn the switch ON and push it hard in the ON position for about 30 seconds. This will 'jump start' your icemaker going again and you shouldn't have any more problems.
Mar 30, 2009 | Refrigerators
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Oct 18, 2008 | Refrigerators
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
