Question about Bissell 1693 PowerSteamer Upright Vacuum
Bissell pro heat turbo will not **** up water,is squirting out water from sides of cleaner-any idea what may bo the solution to this problem?Thank You,Lisa
  • 604 Answers
It may be a seal problem, or perhaps the water tank is not seated properly. make sure the seal is good by running your finger around it and feel for any bad spots, also a close visual inspection may show cracks or holes in the seal
Posted on Mar 17, 2011
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9300 m pro heat turbo 2x . i need the hose diagram for my machine please
I have had problems with the little red clips that squirt the water getting clogged, tiny little holes! I had to remove them and use a needle, then blowed them out with air compressor. I am also trying to find a diagram for this 9300-M model but cant find one.
Aug 26, 2010 | Bissell Vacuums
How to take out the water holder to fill it with water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101 ..,/,
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat
heatman101
ut
Sep 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1693 PowerSteamer Upright Vacuum Logo
79 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
