Question about Cell Phones
How do i turn down the ringing volume? Also what is the enter key?
  • 90 Answers
There should be a rocker type switch to change the volume levels, the enter key is the one in the middle of the arrow keys.
Posted on Mar 17, 2011
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
My phone is not ringing, what should I do. I have a KX-TGA41OC
    A)The ringer volume is turned off. Adjust the ringer volume (page 16).
    B)Night mode is turned on. Turn it off (page 25) A)Adjusting the handset ringer volume
    While the handset is ringing for an incoming call:
    Press {??} repeatedly to select the desired volume.
    Programming the volume beforehand:
    1 {MENU} #160(include the # key)
    2 {??} Select the desired volume.
    3 {SAVE} {OFF}
    B)Turning night mode on/off
    1{MENU} 238
    2 {??} Select the desired setting {SAVE} If you select "Off", press {OFF} to exit
    3 Enter the desired hour and minute you wish to start this feature.
    4 {AM/PM} Select "AM" or "PM" {OK}
    5 Enter the desired hour and minute you wish to end this feature.
    6 {AM/PM} Select "AM" or "PM".
    7 {SAVE} {OFF} When the night mode is set, the night mode indicator is displayed
Dec 18, 2014 | Lands Phones
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
The kx-tga510m phone displays "ringer off". How do I change it to get the ringer on?
To change the ringer volume, press the conf/ function button.
Scroll to ringer setting using the up and down arrow keys.
Press the right arrow key to enter.
Press the right arrow key again at ringer volume.
Press the up and down arrow keys to adjust the ringing volume
Press the save soft key to save entry.
Sep 30, 2010 | Panasonic KX-TG5100 Cordless Phone
I work for the Western Regional Day Report Center in Huntington, WV and we are using one of you Panasonic KX-TG4500 phones and Line 1 will light up when a call comes in, but WILL NOT RING. Now lines...
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Apr 05, 2010 | Panasonic KX-TG4500 Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
I need to make them ring
First check and see if the ringer is on or the volume is turned up.
1st press Feature *6 Press number keys 1- 4 to hear different ring types
2nd - check your volume (Press Feature *80 press volume key up or down
Jun 23, 2009 | NorStar M7324 Telephone
Ring
On most Uniden phones, just press the Volume up key to turn the ringer back on or turn the volume up, the more times you press the button the louder it will get. Conversely, pressing the down volume button will lower the ringer volume, and on some models eventually turn it off.
Mar 25, 2009 | Uniden Cordless Phone
Panasonic KX-TG2343 cordless phone
I'm not sure about changing the amount of rings, but you can turn down the ringer.
1. Press the "menu" key, just below the "off" key.
2. Press the down arrow until you reach "Ringer setting," and then select this by pressing the key just below the screen on the right side (directly above "off" key) .
3. "Ringer volume" appears on the screen - select this the same way as you selected "Ringer setting."
4. Use the arrow keys to change the volume, and then press "Save" by pressing the same key you used to select.
Dec 09, 2008 | Panasonic KX-TG2343 Cordless Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
