When i turn on my laptop it shows a black screen with a flashing hyphen in the left corner and my keyboard doesn't work but only a few keys.all the f1-12 works and tab and esc but enter doesn't which is most important i have no idea what to do now.what do i do? my laptop is a eee pc 1005 HA
    Scholar:
  • 135 Answers
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
My laptop won't boot up. I tried to boot it up with Norton Bootable Recovery Tool, still same problem. I keep getting a black screen with a hyphen blinking on the upper left of the screen?
Most of the time this "hyphen blinking" means your hard drive is faulty. fingers crossed this isnt what has happened to your laptop.
try... turning off your laptop completely... turn it on and then immediately start tapping f10 at the top of your keyboard. tap tap tap taptap taptap taptap taptap taptap tap untill.......
you should get a option for "Vaio recovery environment", you should be able to go through this "built in" recovery and not lose any data.
good luck!
Aug 24, 2011 | Sony VAIO VGN-CS215J/W Notebook
I have a Acer Aspire laptop 4810T. It turns on perfectly fine and everything shows up on the screen but it's so hard to see. The the screen almost appears to be black.
Press Fn key (at bottom left of keyboard) and while holding it down, press F6 key (at top center of keyboard). This should turn on the display screen backlight which had been turned of to save power.
Mar 17, 2011 | Acer Aspire 4520-5950 Laptop
I have a HP pavilion laptop and cannot locate the FN plus button or the on/off switch to turn the wireless on / off.
This would be located on the front left, right below the mouse pad next to the left corner. Its usually a black switch that you could turn left for off, and right for on. when on it should show a blue light, and when off yellow...
Jan 04, 2010 | HP Pavilion dv4000 Notebook
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
Pc wont always turn on and keyboard and mouse wont always work
Sounds like your OS has had some vital system files deleted. you may need to reinstall your OS.
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
Acer Aspire 3100 Laptop Monitor will not turn on
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Dec 17, 2008 | Computers & Internet
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
