Question about Toshiba TDP XP2 DLP Projector
My Toshiba XP2 picture quality was fine until I changed sources. Now it has a blue line at the top and the whole picture has horizontal lines.
  • Fred Towersey Mar 18, 2011
    I have changed the RCA cables and then even changed from a RCA video cable to an S-video and the problem still persists. I am running cables from a multi-media switcher where the DVD and VCR and Wii, etc. It started when I switched the box slowly and had two signals at the same time. Thinking it was the switch box I went and got a new one. then changed the cables and still no change.
    Thanks,
    Fred
  • 2,632 Answers
Welcome to Fixya. If you have blue and horizontal lines on the picture is it possible to change the cables that you are using to check if the problem is caused by the cable?
Thanks
Posted on Mar 17, 2011
  • Rofel Lantican
    Rofel Lantican Mar 18, 2011
    Hi - If you just use the projector to a single device not using the multimedia switcher for example on your pc, do you still have the blue lines? If none then the problem is caused when you connect it to the switcher. If there still a blue line then mostlikely the problem is the projector.
  • Rofel Lantican
    Fred - if you still have a blue lines even connected to a single device the problem is that hardware of the projector. - Thanks
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
    Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
    Oct 08, 2010 | IBM Network Printer 17 Laser
    Toshiba rear projection TV 43VH9UA
    have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
    May 12, 2009 | Toshiba 43H72 43" Rear Projection...
    Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
    Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
    Click Sony CCD Imager Support for details.
    May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
    Blue Screen with thin horizontal white lines
    THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
    call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
    and check video board and all.
    Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
    Horizontal blue line
    The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
    The IC is mounted on a heatsink nearby or around the flyback transformer.
    The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
    Good Luck.
    Jun 20, 2008 | Sharp 25R-S100 25" TV
    Samsung hlp 4663w picture is all horizontal lines
    Bad color wheel...have it checked by a quaified tech.....
    Must have lamp code number to get color wheel #.............T.
    Dec 08, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
    Poor picture quality
    You need to consider the following tips herein as follow:
    1) Field collapse (horizontal white line on screen)
    R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
    2) Picture is horizontally narrowed and deformed
    Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
    Please let me know any update
    Nov 29, 2007 | Toshiba 27AF42 27" TV
    Horizontal lines
    it is due to electrolytic capacitor failure in vertical output section.
    just get it replaced.
    it very very common & minor problem.
    good luck.
    Oct 17, 2007 | Toshiba 27AF43 27" TV
    Toshiba TDP XP2 DLP Projector Logo
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    Branko Djurdjevic
    Branko Djurdjevic
    CheckitRight
    CheckitRight
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
