Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
My son's power wheel won't work. We bought a new battery and charger and it still won't work. Is there possibly a loose wire or something?
    Genius:
  • Fisher Price Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Posted on Jun 19, 2012
Like rider fx wheels won't move
We just bought one of these for our son as well. Put it together, charged it and it simply wouldn't work. After having my father in law who is basically an Electric technician take a look at it, he found loose connections, most notably on the little part that you plug the charger into (the charging diode). After re-soldering a major loose connection found on this part, it completed the circuit for the bike and it started to work.
Best thing to do in this case is that you check all connections in the body of the bike (you can turn it over and take out all the screws on the bottom to get to the major board under the main power and direction switches). But for us the main problem was where the charger plugs in.
Like most Chinese products, these were put together way too quickly and not checked for quality before being put into a box. However, after a little TLC from someone who knows about electric stuff, it is now a great fun toy for our little boy :-)
Dec 25, 2013 | Lil' Rider Black 80-Kb901K Fx Wheel...
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Batteries for Renegade power wheel chair won't charge
if the batteries are OLD they are quite possibly totally dead and need replaced
Apr 10, 2017 | Health & Beauty
Phantom battery won't charge
Hello
Are you sure your battery charger is working correctly. Have you tried it on another battery? Possibly, there is a wiring problem, or your battery is the type that needs distilled water - Try another known good and charged battery with your scooter before purchasing a new one to ensure that the wiring is not faulty.
ilona
Aug 02, 2017 | Drive Medical Mini Phantom Three Wheel...
Won;t power up at all. New batteries but I did not replace back up battery. should I? Tried the contrast fix. Son said he dropped it and it got kicked down hall at school. One year old. Any hope?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
Doesn't turn on or charger is not working
this has happened to me before. the battery is probably dead. so you so buy a car charger and plug it in and the power should be restored since the car battery is powerful. i did it and it worked easily.
May 06, 2009 | SanDisk Sansa Fuze MP3 Player
My battery is not charging and i just replaced charger
There is probaly a loose connection from the input for the charger.
but sometimes thats not the problem.
This happenned to me before , and I just called the company that made the laptop, and they said to just buy a new battery instead of going through the trouble of trying to repair it, which would take about 15-$ and 2 weeks. I would just buy a new battery for about 30$.
Feb 23, 2009 | Gateway M305CRV Notebook
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
209 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
