Question about Troy-Bilt Garden
I just got my troy bilt brand new from lowe and it will not start it seen to be the battier
    Sergeant:
  • 259 Answers
A lot of new equipment have safety switches so they won't start unless you have it in neutral, or have a brake on or you have to have a clutch disengaged.
Posted on Mar 17, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
We have a Troy-Bilt chipper and every time we use it, we have to change the spark plug in order for it to start.
Check the gap on your plug when you put a new one and then check it after you run it normally. If it is smashed check your piston for a contact point where it was hitting the plug.
Check your manual for the correct plug type. They my have put the wrong on in and if you just keep putting in the same plug...
Call troy-bilt they are pretty good about service issues.
Nov 04, 2015 | Troy-Bilt Chipper Shredder 250cc 11.50 TP...
Troy bilt troubleshooting
might be low oil sensor trying to shut the engine down, on a hillside the oil would go to one side and the sensor is thing the unit is low on oil.
Jul 28, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
My troy-bilt chipper vac (4.5)hp engine) will only run a few sec if I pour gas into the engine. it does not seen to be getting any gas. where can I look for the ptoblem? Rich
Look for fuel flow issues, pull the hose off at the carb and see how much volume comes out for how long. if low volume, look upstream. Usually screens get gummed up.
Sep 25, 2010 | Troy-Bilt ChipperShredder
Brand new, troy-bilt chipper model 4265. put oil in engine filled it with gas and tried to pull the recoil starter. It's locked up. I could lift this unit in the air with the recoil starter.
Sounds defective. Even if you could fix this problem something else is bound to go wrong. Troy-Bilt has a reputation for quality products and I'd suggest, since it's brand new, you get it replaced.
Apr 10, 2010 | Troy-Bilt Chipper Shredder
My troy-bilt 70ss trimmer head and or attachments stopped spinning. This is the third troy-bilt trimmer with this problem I have already exchanged two other trimmers within the first 30 days of purchase....
Considering your experience, if I was in your position I would locate the cause of the persistent failure and contact the manufacturer who might be suitably grateful.
I did that once with an inspection light that was bought in from China and brand engineered, as many goods are today, and I received a voucher and the company stopped buying that model. While it didn't help me much it would have helped others.
I am not familiar with the Troy-bilt brand which must be an exclusively US brand. I have used a MAC-60A for 30 years without many problems, a model reckoned by repairers to be a short-lived cheap consumer model.
Dec 01, 2017 | Troy Bilt Tb70ss Gas Trimmer
The rip cord on my new Troy bilt trimmer won't extend all the way
It could be a factory flaw,Ive seen it happen. something inside is probably catching on the plastic cord disk,could have been assymbed wrong and rubbing the flywheel,screw loose on one of the disk keepers,no way of knowing without taking it apart and investigating.
Aug 08, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
70 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
