Question about Garden
Is there anywhere to find a nanual for a yard pro tiller rear tine 8 hp
    President:
  • 1,545 Answers
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Apr 30, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Apr 20, 2010 | Mtd Products Yard Machines 158CC Tiller
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a 1996-1998 MTD yard machines,rear tine, dual wheel,chain drive,counterweight in front, walk behind tiller. It has the traction drve control on the left bar and the gear selection, side to side...
http://www.outdoordistributors.com/MTD/MTD_Main.html
click this link directly
Customer Service Phone Center Hours
are from 8:00 To 4:00 Mon. thru Fri.
(Central Time)
Click Here To See "US"
If You Are Ready To Order,
And Need Assistance, Please Call:
Toll Free 1-877-70-PARTS
(Orders Only Please)
If You Are Not Ordering
But Need
Information Please Call:
1-205-669-2500
More Contact Information
Click Here
one more good link for ordering parts
http://www.milacalawn.com/parts.asp
Apr 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Troy tiller tines
they should point inwards and towards the rear of the machine
Oct 17, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
