Question about Philips 42PF9631D 42 in. Plasma Television
I have a phililps flat screen tv but when i try to turn it on it has the green light for a second but then it goes to the red light blinking it was perfect yesterday i dont know what went wrong today can you please help me.
    Scholar:
  • 126 Answers
You more than likely need to repair your power supply - this is a well known issue for philips sets - pull the back panel off of the tv and check the power supply for busted/leaking or swollen capacitors replace them with the same uf/vdc you can even go a little higher on th evoltages if you would like just keep the uf the same - i would recommend ordering them off the net get the 105 degree ones not the 85 degree ones from radio shcak your tv will last longer if you do.
thanks,
michael
Posted on Mar 17, 2011
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV won't turn on Sylvania LC320SL8 - 32'' LCD HDTV
will turn on tv with remote. stays on green for about 1 second and goes back to red.
Nov 11, 2008 | Televison & Video
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Philips 42PF9631D 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
