Question about Cameras
We bought our son a Vtech 1070 camera with mp3. However, when I copy music files to the camera or the sound card I've put in, I get the message music files not found! it appears to copy perfectly via internet explorer, and shows the files on the camera or on the card - but when i turn the camera on and try to access them, I get the same message both via the camera and the sound card. Help!
SOURCE: Olympus 2G xd M card with pictures - error message "clean card" or format
I also have had this problem.. I rang Olympus & they sent me a Digital Image Recovery Freeware.. Im currently trying that. They told me that for some reason wen we put our XD cards in our card reader it puts a file on the card, which can sometime corrupt the card. If you cant get the pic off your card using a recovery program, you can send away & get it professionally done..(probably at a cost). The only way to get rid of the error is to format your card again try to remember to upload pics with your cable rather than the reader.
(Fingers crossed I can get my images from this software)
Posted on Jun 05, 2008
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
The trouble with trying to format large cards of 1Mb or 2 Mb is that in order to do so you need your original card or a card that currently WORKS. I have one of 16 Mb. Go to Fujis web help page and download the firmware fix "FinePixA340" to your PC. Run and extract the data file "FPUPDATE".Now you have to put this file onto the old card. I pasted it so it was "beside" the DCIM folder ( NOT the next one down 100_Fuji folder or it won't work). To copy and paste you may have to connect the camera to the PC or use a XD card reader/writer via a USB port. Having done that, put the card back into the camera if you used a XD writer and switch off the camera. For the next bit make sure your batteries are good or connect to a power supply. Hold down Disp/Back button and THEN turn on camera. It should have detected the new firmware data file. Follow the simple instructions-say yes and let the data file load--takes a few minutes. The camera should say the new version !.22. Now that the firmware has been updated , you can now format your NEW LARGER cards 1 or 2 MG. So take your old card out ,put the new card in and format. It worked sweet as a nut for both 1 and 2 MG. The trick is to use a card that already works,load firmware file onto this , update file onto camera, then format a larger card. Its what they don't say exactly that causes frustation. Happy formating campers
Posted on Dec 04, 2008
SOURCE: I have a vtech kidizoom pro camera and have tried
I bought one for my 7 year old. install the cd that came with it first before you attach the usb lead. Open My Computer - find where the Vtech is. then open your computer folder where your music is mp3 mp4a which ever you have highlight the song then then "copy file" select your music folder in the directory where the vtech is located . I do not have an sd card in hers yet. Disconnect turn the dial to the music selector on your v tech make sure the volume is up ! I made that mistake first
Good luck hope it helps
Posted on Dec 26, 2009
SOURCE: cant transfer music files from computer (through
I discovered exactly the same problem. I get an errormessage saying that there are no music-files inside the folder.
I discovered, that creating a ne folder from the Windows-Explorer (not copying, but creating!) I can afterwards store mp3-files inside that are displayed correctly. Even if I ove from the PC-side those mp3-files on the SD-card that are supposed to be invisible, they are also correctly displayed. I assume there is a bug in the camera-software. I have asked Vtech to provide a solution. We will see.
Werner
Posted on Jan 24, 2010
I've copied some dance cd's to my sd card so I can
Sorry but you can't. The pause in the middle is the music player buffering. If you desperatly wanted to remove it you would have to download software like audacity and individually join each mp3 file.
Hope this helps, but dont forget to help me by leaving a good rating :)
Jun 05, 2011 | Sandisk 4 GB Standard SDHC Card with Rezo...
Hello and good day, I just bought a Nextech SD card for my son's DSI. when we inserted it and tried to open the music files through it. there a message of " Cannot find any music (compatible AAC files on...
As the warning said the music files aren't in the correct format, the only one supported by your device - aac. Most likely the files are in mp3 format.
If you want to use them on this device you must convert them. Use this program for that:
http://www.softpedia.com/get/Multimedia/Audio/Audio-Convertors/AAC-to-MP3-Converter.shtml
Jul 30, 2010 | Computers & Internet
Cant transfer music files from computer (through usb) when copying and pasting from folders to removable disc. When I turn the camera on the folders appear but the music files aren't there
Werner
Jan 20, 2010 | Vtech Kidizoom Digital Camera
Getting music from itunes to windows to mp3
that shouldnt make a difference. if you plug in the mp3 it should give a few opition ie open file leave that open go to my documents where the music saves and brag them over
Jan 13, 2010 | Audio Players & Recorders
Casette to disc
to convert music from cassett to disk u need to connect the cassett player headphone jack / line out jack to ur PC/laptop mike / line in jack....then play the music and record it in a software(Nero Sound editor etc)
then once that's done save it as mp3 file on to ut PC and trf it to ur cd/disk....u can just copy it as mp3 or create a music cd using Nero...from the mp3 file
the difference is if u just copy the mp3 on to the cd then only a mp3 player/mp3 music system deck can play it... if it's created as a music cd then any cd player can play it....just like any music cd that u buy in the mkt...
a 700 mb disk can hold almost 7 to 10 hrs of music in mp3 format....
but a music disk can hold only 80 mins of music
Jan 03, 2010 | Dell (3996D) Sound Card
I have a vtech kidizoom pro camera and have tried many times to put music onto the camera but it just comes up on the camera as muisc files not found even though when the camera is attached to the computer...
Dec 01, 2009 | Vtech Kidizoom Digital Camera
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Music download doesn't work
Make sure you are transfering the actual file and not the icon. Better to copy and paste it than use media player or some other program
Jan 24, 2009 | Vtech Kidizoom Digital Camera
Can't upload mp3's onto camera
To transfer MP3 files to Digimax i6:
- Turn off camera
- Plug USB cable to PC and camera
- Turn on camera
- On your COMPUTER screen, it will tell you select USB: Printer or Computer
- Select Computer using the arrow buttons
- Press MENU/OK
- On your COMPUTER screen, a window will pop out like
Removable Disk and it will be telling you a lot of options
- Select "Open to View Files"
- You should be seeing the DCIM folder as you select that option
- Right click on the white space where DCIM is located
- Select "New" and then "Folder"
- Rename the folder as MP3
- Open your documents containing the MP3 files that you want to transfer
to your camera
- Make sure that the format is MP3
- Select the files that you would like to transfer
- Right click on one of those and select copy
- Now, go to the MP3 folder that you've just created
- Open the MP3 folder
- Right click on the white space of the MP3 folder
- Select PASTE
- All MP3 files will be copied to your camera
Note: It depends on the file size of your MP3 if it could still
be accomodated inside your memory card
To safely unplug your camera:
- Look for the green arrow icon on the lower right corner
of your computer
- Right click on that and select "Safely Remove Hardware"
- Just select your memory card in there that is pertaining
to your camera and select stop
- Once, you've seen the message "You could now safely remove the camera",
then you could now turn off your camera and unplug it so as to prevent any problems
On your camera:
- Turn it on
- Press the M button
- Scroll to the right until you see MODE menu tab
- Use the down button to select Still/Movie/PMP
- Press MENU button (all will disappear)
Now,
- Select Resume
- Make sure to be on MP3 mode
- Select the desired files and those will play
If it still does not work, call the Manufacturer.
Jun 23, 2007 | Samsung Digimax i6 PMP Digital Camera
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
