Question about Siemens Washing Machines
Our Siemens IQ 1430 is registering a 'blocked pump', but I am unable to twist open the cover on the pump acces shaft (bottom right). This cover will not turn the full 90 degrees to the left and so I cannot get it open. I have read elsewhere (on a german website) that this is due to an obstruction in the pump and that you have to take off the whol front of the machine in order to get into the access shaft from the back. Unfortunately my german is good enough to understand this but not good enough to understand the instructions for taking off the front of the machine. I would be very grateful if anyone out there can provide me with this information in english. Many thanks in advance! Kate.
SOURCE: LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi IZ 12 pump access
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
Posted on May 26, 2009
SOURCE: siemens serie iq 1430 start problems\r\nThe
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Posted on Sep 28, 2010
rylee_smith
  • 8619 Answers
Hi
Thanks for using FixYa. If it won't flash any error code then the issue is with its Electronic control going bad and should be replaced. However, before replacing the panel check the door switch as if that's bad you'll have to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Siemens iq 300 washer
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Enter IQ 300. You will be presented with a list of common repair parts and may be able to view a general video showing how to disassemble it.
May 26, 2016 | Washing Machines
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
Need to sell mxl-iq system great shape
try local newspapers, pawn shops, or craiglist , or smaller auction like websites
Jan 22, 2014 | Siemens Mxl-iq Iq-cp-int Smb-2 & Mkb-4
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Siemens iq 1430
I'm unable to remove the child lock on my seimens IQ 1430 washing machine
Sep 09, 2010 | Washing Machines
My Siemens Hydrosensor dishwasher seems to go through the entire cycle but at the end mainly the top rack of dishes, sometimes the bottom rack is completely covered with a film of junk. It ends the...
It is obvious the drain or pump out is not working. There is a blockage in the outlet. Check the drain under the sink nby removing the hose and making sure the hole is not blocked. The pump in the dishwasher may be blocked. fixing this may not be within your field of expertise and a technician may be needed. Good luck
Jul 31, 2010 | Siemens 24 in. SE53200 Built-In Dishwasher
My siemens washing machine S14.39 keeps stopping at display F:18
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
May 18, 2010 | Washing Machines
Install New Belt
Lift the headlight and rotate the thumb dial to release the carpet head. It will spin to the side. Rotate the square handle at the front of the vac fully to the left.
Remove the carpet head and open it from the bottom side. Observe which side had a little block below the LED belt indicator when you rotate the brush. The brush must go back in this way. The blocks at the end of the brush are color coded for height adjustment. Remove the brush, slide a genuine belt onto the center and close the bottom cover of the housing. make sure the brush spins freely, now look into the belt opening, round hole at the side. Using the square dial at the front of the head, rotate the hook into the belt to twist the belt and open it for installation onto the motor shaft.
Reinstall the head onto the vac, using the thumb dial to lock into place and rotate the square handle again . This will release the belt tension onto the motor shaft. Raise the vac up two knotches with the pedal before lower onto the carpet.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Washing Machines Logo
177 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
