I just want to know if I can hook speakers up to it without going through any other electronic device. It has output on the back with L and R on it .
  • 3,018 Answers
If the "L" and "R" are marked for speaker output the yes it can. That what a receiver does.
Posted on Mar 17, 2011
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
Jan 29, 2014 | Kenwood KDC-MP235 CD Player
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
No Sound. We moved the computer and now no sound.
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Oct 17, 2009 | Samsung SyncMaster 172 W 17" LCD Monitor
Can I hook up my steroe speakers to the TV? I have an older model
If your older model TV has red and white plugs on the back of it that say something like "Audio Out" or "Output" then YES.
Simply connect a pair of RCA Cables (available any electronics store) from the Audio Out jacks on your tv to the "AUX" input on your stereo.
You cannot power speakers without some kind of stereo/receiver.
If you do have a receiver then you can connect to your "TV INPUT" on the back of your receiver and control the tv volume with your receiver remote.
If your tv does not have those red and white output jacks then there is no practical way for you to connect your speakers.
Aug 15, 2009 | Durabrand Televison & Video
Hannspree Monitor speakers wont work
I don't know if I caused the problem or not. I hooked up my new Hannspree HF237 monitor to my HP pc, and the sound wasn't loud enough so I hooked up my external speakers, and got nothing. So I disabled one without the other, and still got nothing. Now I can't even get the monitor's sound to come back on. Any ideas?
Jun 10, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
I HAVE A CERWIN VEGA CLS-15S POWERED SUB AND A PIONEER RECEIVER WITH NO RCA SUB HOOK UP ON BACK. HOW DO YOU HOOK IT UP
flathead30,
This is an old question but if you have not yet figured anything out, hear is a suggestion.
Without buying any other electronics, use your tape output on the receiver and let your sub's built in crossover to filter the highs out of the signal.
-Chris
Apr 16, 2009 | Athena AS-F1 Main / Stereo Speaker
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
How can i install a new Computer Speakers? I had some speakers on my computer and it stopped working. I thought my speakers were messed up so I got some new ones and now my computer says that there is no...
This sounds more like a sound card issue. Go to Control Panel, System, Device Manager and check your sound card.
The speakers get plugged into the audio output jack on the back of your computer.
Jun 03, 2008 | Audio Players & Recorders
Kenwood system with tuner, cd player, casette player,intregrated amplifier and stereo power amplifier
This website sells the owners manual for $9.99 and the service manual for $14.99 your stereo:
Here is the website:
http://www.user-manuals.com/advanced_search_result.php?keywords=KA-996&x=11&y=15
Hope this helps.
Could be too many different reasons for no/low output. My 1st guess would be the output transistors, but that again is guessing without knowing more info about the receiver.
Hopefully, its is something simple like the way it's hooked up, or if you have the wrong channel selected.
Good luck.
Feb 02, 2008 | Audio Players & Recorders
20 people viewed this question
 Grubhead
Grubhead
