Question about Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
The fuse on my circuit board keeps blowing after a thunder storm. Need to replace the entire circuit board for my RS8 system. Any sugestions on where I can purchase just the circuit board? Mike
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Unplug all the aux plugs but mark them replace fuse turn on if it still blows need a new board if not plug in auxs 1 at a time till it pops then check out that aux for shorts sometimes the relays short out
Posted on Nov 12, 2014
No lights,no clock no functions. Power to the unit is good. Any suggestions?
The likely cause for your radio not functioning is a blown fuse on the power supply circuit board. Unless you are able to take the clock apart and solder a new fuse to the board, your best option is to purchase another radio. If this clock radio is a wall plug-in, the fuse may have been blown during a thunder storm.
Mar 24, 2015 | Audio Players & Recorders
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
Internal fuse
no they dont, you can check continuity down to the board and also look on the board for any blackening caused by shorting iut
Apr 07, 2014 | Washing Machines
WE HAD A LIGHTING STORM AND I HAVE NO LIGHTS ON MY BRAVIA WILL NOT TURN ON IS THERE A BREAKER OR FUSE TO LOOK FOR
There is a fuse in the tv power supply board,a fuse it is located near the a/c socket plug in of the tv power supply board.Lighting storm pack a huge anount of power and magnatic static field.If ur tv was in that path.U will not fixed it with a new fuse the tv whole power board probally dead already and those other circuit boards on the tv might be dead too.Good look with the replacement of the fuse,maricles might happen ur tv just have a dead fuse only.Not must take to or call many tvs shops and get the best estamates prices to fixed the tv.Not a do it self project,if tv a got hit by a massive power surges.
Aug 11, 2011 | Sony BRAVIA KDL-46V3000 Television
Fuse #109 keep blowing/ driver seat not working please help
If the fuse keeps blowing, I assume it is because you keep replacing it. Those fuses have given up their lives to keep your truck from burning to the ground. Each time a fuse blows, the wires in the system get heated up and weakened. If you keep replacing the fuse, the insulation will eventually burn off of the wires and light the entire truck up. There is a shorted component or wire on one of the circuits that are protected by that fuse. Replacing the fuse without locating and repairing the reason that it blew, will only result in another fuse having to give up its life to keep your truck from roasting and all the other fuses will have died in vain.
The circuits to that fuse will need to be traced, using the wiring diagrams for your vehicle and the proper equipment necessary for performing tests on your electrical system. Nobody online can tell you what the actual cause of the problem is (other than tell you there is a short) without performing the necessary tests on the vehicle itself.
Jan 29, 2011 | 2006 Ford F-150
During a thunder storm our polaroid tv went out..we have changed the fuse but it still isn't working..any other suggestions?
Call your homeowners' insurance agent. Seriously, if the set is worth more than your insurance deductible, you will want an expert evaluation on whether the set can be profitably repaired so you can make a claim if necessary.
Was the first fuse blown? Did the second fuse blow? If the answer to both questions is yes, then you have a fried power supply switching transistor - at a minimum. You might even see cracked or burned parts on the board that has the fuse on it (look at the parts on or near the finned metal radiators). Lightning typically damages a number of parts. You may find it cheaper to replace the entire power supply board, and hope the rest of the set isn't damaged.
If both fuses are good, that could be worse news, because that implies lightning got in through the antenna/cable input and zapped the main circuit board. This is the second-most expensive part of the set after the LCD panel.
A suggestion for "next time": if a TV set blows a fuse, get the problem fixed first before risking a new fuse on it. It's rare that a power surge blows the fuse without also breaking something else. The fuse is intended to minimize damage and prevent fire in case something in the TV shorts out or the surge protection components are unable to handle a high energy pulse on the power line. It's not guaranteed to protect the set from damage.
Oct 24, 2010 | Polaroid TLA-04011C 40 in. LCD TV
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking...
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
Jul 19, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Aug 01, 2009 | Emerson EWL3706 37 in. LCD Television
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux)  RSP8 () Logo
108 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
