When connected the charger then windows restart by itself
    Master:
  • 325 Answers
If this happens at the moment that your charger gets connected then its probably a loose connection on your socket
see http://www.2pages.co.uk/laptops.html
bottom left, socket damage
Posted on Mar 17, 2011
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Why does my Motorola Admiral not turn on automatically when it's plugged into a charger?
it's not to worry about your phone when your phone does not start automatic because in the only region off your better dead. you just live your phone into a charge sometimes after you can see your phone is automatic restart
May 17, 2017 | Cell Phones
My advent QRC430 laptop keeps restarting when i put it on charge!
One of 2 things are happening. Either the charger is putting out more power then its supposed to and the board bios is saving itself or the board a/c adapter is dead-shorting. You can order a new a/c charger for around $35 so shop around. You can also check it with a volt/Oem meter. If the charger says its a 12volt output and its putting out 24volt according to the meter then u know where your at and know the board has an issue. Keep in mind the charger is a cheap fix the connector pin shop average is $150 the board replacement around $285
Mar 28, 2010 | Computers & Internet
Toshiba laptop won't start up
Try this:
  • remove battery
  • replace battery
  • restart
Then:
  • with charging cord plugged into computer and wall restart
If it starts on the battery the computer has reset itself-- you're good to go...
If it starts on the wall charger but not the standalone battery... the battery is the problem.
If neither works replace the charger cord.
Good Luck
Jeff
Sep 13, 2009 | Toshiba Satellite A205-S4777 Notebook
Windows will not start. Computer restarts while loading
good day sir/maam, there are several reasons why the windows restart.
  1. Power supply or charger problem. To solve this you may need to find another charger to use on your laptop.
  2. Battery problem. try a new battery.
  3. systemboard problem. sad to say this but you may need to bring it to your vendor for service
  4. poor Windows installation. you need to reinstall windows
  5. Memory. replace the memory module.
The most common culprit is number 1 and 2. if not try the rest. may this guide you.
Aug 04, 2009 | Dell Latitude D800 Notebook
HI I have a dell Vostro 1510.There is a problem with my system since yesterday .when I have connected my latop to the cahrger My laptop swiched off .And I am never again able to restart it.Later observed...
dear,
did u check the charger itself...its important ...
if you have multimeter then unplug the charger from laptop and plug the mains from socket to th charger plug and check the output DC voltage..is it coming, if coming then is it constant or varing ...if varing then u have to check the charger inside by an expert...
if its ok then remove the battery of the laptop and plug the main to charger and charger to laptop and then check its performance by switching on laptop...if its work then battery issue....
Aug 03, 2009 | Dell Vostro 1510 Motherboard System Board...
Laptop Will not load past the windows loading screen
BOOT UP INTO SAFE MODE AND LET WINDOWS TO TRY AND FIX IF YOU DO NOT DO THIS THEN YOU ARE GOING DESTROY THE MASTER BOOOT SECTOR ON THE HARD DRIVE AND THAN YOU HAVE TO PAY SOME ONE LINKE ME TO REBUILD THE MASTER BOOT RECORD, UNLESS YOU MAY HAVE ALREADY DONE
CANDYMANGANDY
Jan 29, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
