Question about Saeco Starbucks Sirena Espresso Machine
My Barista shows no activity when the start switch is depressed, no light, no boiler warm up noises. It acts like it's not plugged in but the pump works just no activity in the boiler. No burnt smell or signs of a short.
  • 1 more comment
  • apprei10 Mar 18, 2011
    I assume that when you say heater, you are referring to the boiler.
    Also, do you know where I can order parts?
    Thanks for the help,
    Frank
    I just re read your answer and I think I've got it straight in my head.
    Would still like to know a source for parts.
    Thanks again
    very helpful
  • 4,924 Answers
If the boiler does not give any sign of working ..it is in most cases the heater to blame ...So check it ..and change it if it is the case ...(it may be just a disconnected wire from a physical shock )..cause the boiler is nothing else but a can with an electric heater ..and the heating unit is the only thing that can be gone bad ...
Posted on Mar 18, 2011
Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Mar 06, 2010 | Saeco Starbucks Sirena Espresso Machine
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Apr 24, 2009 | Combi Centre DX - Mango
ERROR 203 on MEIKO MODEL D 120.2
error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
Jan 21, 2009 | Meiko FV 130.2 Dishwasher
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
No longer have instruction manuel
Few possibilities:
Water lines clogged, boiler valve housing problem, flow meter bad, pump is bad, boiler is bad, CPU is bad, or grinder issue. Have a SAECO Authorizes
SErvice Center assist you.
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 04, 2008 | Starbucks Saeco Italia Digital Barista...
Rancilio silva
Hmmm. It doesn't sound like a boiler problem. The heating element is controlled by a pressure or temperature switch. Either the switch is poorly connected or malfunctioning. Temp. switches are directly on the boiler with wires that go to a relay connected to the heating element. Pressure switches just have a tube connected to the boiler with wires to the relay.
Jan 25, 2008 | Rancilio Silvia Espresso Machine
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Saeco Starbucks Sirena Espresso Machine Logo
404 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
