Question about Zanussi TC180W Electric Portable Dryer
Indesit dryer IS70CS
Hi, my dryer is working apart from the heat! Its spins round ect,but no hot air! Could you please help? Thanks
    Problem Solver:
  • 11 Answers
Sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Posted on Jan 24, 2009
DOOR SWITCH WONT WORK
Lift the panel, and you'll have access to the switch. Simply pull off the connections on either sides of the switch and push them onto the proper connectors on the new switch, and fasten the switch.
May 07, 2012 | Indesit Dryers
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Indesit wd125 - everything works but the dryer doesnt get hot - wont dry
heatman101;';
Jul 19, 2011 | Indesit Dryers
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
heatman101
Mar 15, 2011 | Dryers
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 05, 2011 | Indesit Dryers
We have an indesit is70cs. The empty water light will not go out (even though the water drawer is empty). So this means we are not getting any heat to the washing. We have cleaned out the filter and...
empty light is operated by a microswitch in the box where the pump is and fault can be:
pump faulty
microswitch stuck in up position.
to access, remove small panel on rhs at back and box will come into view
Aug 31, 2008 | Dryers
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Hi, My Indesit WIDL 102 is faulty. It washes OK, But does not dry at all. I dont think it heats up during the drying time, but the drum does turn round. Is there a thermal reset switch on the inside...
I don't know your dryer model, but I assume it is electric. Electric dryers have a heater coil like a toaster which eventually wears out and doesn't get hot anymore. This is typical and is likely the case especially if your dryer is old or has been used alot. Has the dryer been taking longer and longer to dry before it lost all heat? If so, I bet it is the heater coil.
Zanussi TC180W Electric Portable Dryer Logo
387 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
