Question about Sony Ericsson K750i Cellular Phone
Mobile fault i have a problem in my ringer section it rings but not so loud.
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
My mobile is nokia 3110classic.suddenly i got a sound problem.i cn't hear sounds outside.but am ble hear them through ear phones.i.e am unable hear songs as wells am not able to hear my ring tone...
The problem is with your "Ringer" (the bigger speaker). If you can hear the sound through your ear piece, then replacing the Ringer/Speaker will definitely fix your problem. I would suggest to get it done from a service center or from a mobile repairing shop.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Nokia 3110 Cellular Phone
I have a NOKIA 2610b go phone, How do you turn up the volume on the ringer?
I've worked in the cell phone industry for many years. The big Nokia phones is that most of them never ring very loud. The have a history or blown speakers when they have loud ringers.
Try going under Profiles and changing the ring to outdoors. that will make it ring louder but probably still not loud enough
Oct 13, 2009 | Nokia 2610 Cellular Phone
How to change ringtone
that setting is in the ringer profile section... you have to set it for each profile ....
Go to
SETTINGS
AUDIO
(ringer profile) DETAIL [change]
VOICEMAIL [change] select the sound/ringer
You must do this for EACH profile setting if you use a different profile
Aug 30, 2009 | Motorola Mobility RAZR V3
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Phone ringer is too loud
WHILE the phone is ringing, push the down arrow key.
Aug 27, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Turn off ringer
No specific knowledge of your model but I have seen many people place tape over the housing holes for the ringer to cut down the volume level on phones where the ringer is too loud.
Jun 14, 2007 | Southwestern Bell GH-5812 Cordless Phone
Sony Ericsson K750i Cellular Phone Logo
21 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
