Question about Dryers
My dryer isn't drying with heat/ - Dryers
  • yadayada
    yadayada Mar 17, 2011
    That makes sense to me.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Electric dryer heats up and blows air but doesnt dry my clothes
I would check to see that the lint/filter isn't completely clogged up. This could make the dryer warm without allowing it to do its job of drying the clothes.
Also, is the drum spinning? If not, it could be indicative of other problems.
Nov 13, 2012 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
MAYTAG QUIET SERIES 200, THE DRYER ISN'T DRYING NOT HEATING CLOTHES
this problem could be that the heating element in the dryer is not working and may need replacing
Aug 14, 2011 | Dryers
Dryer runs but does not dry clothes
Dryers run on two circuits. One runs the motor and the other runs the heat. Check to make sure the fuse isn't blown or the breaker isn't tripped. Usually there is a fuse box behind the dryer with two fuses. One is for motor, one is for heater.
Jul 24, 2011 | Dryers
heatman101
Jul 22, 2011 | KitchenAid Dryers
The drying light is flashing and the dryer isn't heating up
heatman101[]\==-
Jun 26, 2011 | LG DLE2514 Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
