Olevia LT37HVS 37 in. LCD HDTV Logo
Posted on Mar 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't use the channel up and down key to search channels
Veril Gillette
Level 3:
Genius:
  • Master 1,126 Answers
  • Posted on Mar 17, 2011
Veril Gillette
Master
Level 3:
Genius:
Answers
1126
Questions
0
Helped
213122
Points
3124
The processor is locked up, unplug from the waqll and it will be fine.
How do I tune in my TV LE26R73BDXJXEU AEL53SDL704282P AM01
First, make sure that the source is set to TV. (Use the TV button at the top left of the remote to ensure that the TV is being controlled by the remote. The Source button is the one to the right of the Power button on the remote. It's the top button on the side of the TV. ) Next press Menu. (On the remote, it's the button to the upper left of the arrow keys. It's the second button from the top on the TV side panel.) Use the Up/Down arrow keys to navigate to Channel. Press Enter. (Note: the channel buttons at the bottom of the side panel buttons match the Up/Down arrows of the remote. The Source button on the TV is the Enter key.) Press Enter again and use the Up/Down arrow keys to highlight your country. Press Enter. Navigate to Auto Store and press Enter twice. Wait for the TV to go through the channels and test for signal.
You can also add channels manually by using the Manual Store option. If you know the channel number, you would then choose Channel and select C (over-the-air) or S (cable) and then the Right arrow key. Use the arrow keys to highlight the desired channel. Press Enter. Use the arrow keys to select Store and press Enter again. Otherwise choose Search. Use the Up/Down arrows to select a channel. Press Enter, go to Store and press Enter again. Repeat this for each channel.
The manual for the LE26R73BD is available on the support page: https://www.samsung.com/uk/support/model/LE26R73BDX/FID/ . The current link to the manual is https://downloadcenter.samsung.com/content/UM/200603/20060325173246984_BN68-01007A-00Eng-0302.pdf.
I hope this helps. If you use a set top box with a non-RF coaxial cable output to the TV, the channel option will not be available.
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
My 90 year old mother cannot step through the channels using the up and down arrows, or display a guide. Can you help me help her? Toshiba CT-90302
Hello; You did not give much info here. If you are on cable TV and are running it directly to the TV with NO boxes between the cable from the street and the TV, You must do a channel search or active channel memory. Read/ download the owners manual to perform the channel memory search. When done you can just key in the channel you want on the remote control. John
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
2helpful
I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
First of all make sure all the leads are connected to the TV.
Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
Now you will need to perform an all channel search.
Press the Menu key to display the main menu.
Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
Now you may need to perform a digital cable search to pick up your satelite digital signal.
Press the tuner key on the remote and then the menu key.
Use the cursor key to select Digital cable search and press enter.
Now the TV should scan for a digital signal
Good luck and kind regards.
8helpful
3answers
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
3helpful
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
2helpful
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
10helpful
3answers
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
