Require code for pan 50vt20 - Televison & Video
  • 902 Answers
Some codes to try are 0051 678, 254, 278, 154, 242, 241, 368, 128, 191 as i dont know what remote you have. you may also try 100, 101, 130 need more info on what remote you have
Posted on Mar 17, 2011
Yesterday I bought an touch induction ,and now E1 error code is showing And just I have to make the food what should I do??
those require special pans /skillets that have steel in the bottom. test your pans with a magnet . if they do not stick to it they will not get hot .
Oct 10, 2016 | Kitchen Ranges
How do I reset after putting on new oil pan? It won't start now
If you replaced the oil pan properly look to another system. The pan should not be the problem.
Aug 11, 2016 | Cars & Trucks
How do i change oil pan gasket
Depends. On some cars you can remove the pan with engine in the car. Drain it, remove all bolts and remove pan. If stuck, use putty knife to help free it up. Some cars and trucks , especially 4wd may require removing motor mounts and jacking engine up some. Some require pulling the engine.
Feb 13, 2015 | Cars & Trucks
How do i change transmission fluild an filter
Hi J, Clean the whole area around the drain plug and oil pan. Drain the fluid from the drain plug at the lowest point of the gearbox oil pan. When drained into the required receptacle, remove all bolts around the oil pan and drop it. The oil filter is located inside and held in place by fixing bolts. Remove those and replace the filter. This job requires the utmost cleanliness, and no contamination should be allowed to get inside the gearbox. Refit oil pan using a new gasket and refill gearbox to required level. Always check the gearbox level with the engine running, the selector in neutral and the park brake fully engaged. Regards John
Nov 16, 2012 | 2007 Toyota 4Runner
I have a ford focus 2000 the checkligth is on the cods showmi is po760 can yu heolp mi what is the problem please
Unfortunately, this generation Ford Focus was known to have common auto transmission issues and this code relates to a shift solenoid circuit (there are 6 electric solenoids inside your automatic gearbox). These solenoids are responsible for the shifting behaviour of your automatic transmission.
Trouble Code P0760 = SSC (Shift Solenoid "C") Solenoid Circuit Failure .
SSC circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. Not all gears present.
This repair is very simple:
The malfunction has ocurred in solenoid "C" circuit, so it will require someone to:
1) Raise front of vehicle and stabilise on suitable axle stands or ramp.
2) loosen transmission pan cover bolts and undo one side of the transmission pan cover only, just enough to drain the trans fluid into a suitable container.
3) once fluid is drained, undo remaining bolts on pan and remove pan from trans
4) all 6 solenoids should be visible - locate Solenoid C. Unplug wiring and test the solenoid with a multimeter to determine if solenoid is within factory spec (you'll need Ford's solenoid spec's to do this).
5) if solenoid C is not to specification, then remove from single bolt holding the solenoid in place and replace with a new solenoid (approx. USD $60 from Ford).
6) Putting pan back on must be done with careful attention as follows:
i) clean the surfaces of the pan & transmission carefully, without damaging any surfaces.
ii) using liquid RTV gasket maker, spread a thin bead along the edge of the pan - just enough to seal the pan, without spilling into the transmission casing.
iii) refit pan and torque down all bolts. Allow the liquid RTV to cure properly (as per intructions on tube).
iv) once RTV has cured, refill transmission with new FORD approved trans fluid (do not use non specified fluid). You will get an idea how much fluid you'll need, compared to the amount drained.
v) Fill up with 75% of the required fluid to begin with - just enough to allow idling of the engine for further checking.
vi) run engine at idle to warm up transmission.
vii) when warm, move gear selector through all gears, then rest lever in Neutral.
viii) check fluid level with dipstick - add approx. 1 cup of additional fluid at a time, until you reach the correct level.
To ensure the pan is sealed correctly, check for trans fluid leaks under the vehicle, during the following week.
Hope this helps....
Nov 01, 2011 | 2000 Mercury Sable
We have a hoptpoint ultima super silent fdw80 dishwasher, displaying the code AL01, we have already tried the the 2 solutions listed & the fault still shows, any ideas?
You have a leak around the pump area and need to locate and repair this to use this unit. This fault code is to protect you home. This mean your unit is leaking during use and water is collecting in the base pan. You may need to run the unit were you can see the leak to repair. If possible you may also check you drain hose, it that leak it can also drain back into the base pan.
Good Luck
Aug 28, 2011 | Hotpoint 24 in. FDW60 Free-standing...
The service engen soon light is on it a 1997 Chevrolet truck K1500 4WD pickup 5.7 8Cyl Emissions-related Powertrain DTCs, Mode 3: Electronic Control Unit ID: 10 P1870 Manufacturer specifc...
Code P1870 is a transmission code for excessive slipage. this can be caused by allot things inside the transmission. clutch wear, seals worn out. some checking will be required. the first thing to do, is have the vehicle driven with a scan tool that reads real time data. just a code reader. this will pinpoint the problem to the inside of the tranmission. in some cases just a replacement valve body inside the trans will correct this code. another way you can handle this, drop the transmsission pan down, if there is allot of debris in the body of the pan, then you can pretty much count on a complete overhaul of transmission
Jun 09, 2011 | 1997 Chevrolet K1500
For a noritz N-06315 do I need an aux drain pan if it is installed above a living space
It depends on local code, no all cities/states require drain pans, but it is always a good idea if you don't want to deal with water damage.
Jul 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
What is the size of the allen wrench needed to fit the oil pan drain plug in a 1995 toyota celica
The oil pan drain plug should require a 14mm hex head wrench to remove. The transmission pan requires a 10mm allen head socket, or wrench to remove. Are you sure you're trying to remove the correct drain? The oil drain should be on the passenger side and on the rear corner of the pan.
Dec 12, 2009 | 1995 Toyota Celica
How can we get to the base pan in our asko d3350 dishwasher? we are getting f2 code= empty base pan due to an overfill.
if this is an under counter unit you will need to remove the unit to gain access to the sides where you may be able to drain that base pan. some of these fancy things require you to remove the side panels to get to that pesky base pan..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Asko Dishwashers
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
