Question about Nikon COOLPIX S230 Digital Camera
Can this camera auto focus? - Nikon COOLPIX S230 Digital Camera
    Top Expert:
  • Nikon Master
  • 76,846 Answers
Yes this camera has auto focus.
Posted on Mar 17, 2011
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
My camera turns on but it won't focus on automatic and when I press the button to take a picture it won't take one on manuel or automatic.
There may be a few things preventing the camera from taking a picture. I don't know the lens you are using but by chance does it have an auto/manual switch that has been switched to manual? Also make sure the lens is locked in position. The camera won't take a picture unless it has focus in the auto focus mode, this is normal. What are you trying to focus on? The camera auto focus system will search and fail to auto focus on surfaces that have little or nor contrast. For example glass, chrome, a blank wall, water, blue sky. Other conditions that auto focus fails is being to close to your subject, heavy fog, a dim lit subject, available light and night photography. Once the little green confirmation light comes on the camera has focus and will operate as it should.
Nov 27, 2010 | Canon EOS Rebel XS 35mm SLR Camera
AUTO FOCUS NOT WORKING. SOMETIMES IF YOU REINSERT BATTERIES THE FEATURE WORKS AGAIN
Auto focus for an for digital cameras have a nasty habit of that, do what I do, and my Auto Focus works too, but I use Manuel focus all the time, and I shoot professional golf....I never auto focus nothing....my eye is faster and better than the lens.
Mar 22, 2010 | Nikon D60 Digital Camera
Lens will not auto focus with flash up
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
Oct 11, 2009 | Nikon D60 Digital Camera
Auto Focus not working
It depends on how long you have owned the camera, but I find it doubtful that it would be waring out. Sometimes after messing with the auto focus buttons my camera no longer focuses on its own, I then reset the settings and re-select auto focus. This always fixes my problem. I hope you find a solution. God bless...
Aug 16, 2009 | Cameras
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Low light with auto-focus
All auto-focus systems need a fair amount of light or contrast to work efficiently. If possible, raise the ambient light if indoors. Search for an area within the desired focusing point with contrast to focus on.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Nikon COOLPIX S230 Digital Camera Logo
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
