Previous air flo problem whirlppol cabria now it freezes up when it turns on
  • 1,940 Answers
If the motor is freezing up during a wash, this could be a broken RPS sensor, a worn motor, etc.
If the Control Panel is freezing up, this could mean you have a faulty control board.
Use the following Tech Sheet and run your Washing machine through the Diagnostics Test:
http://www.4shared.com/document/xQgJ4Odg/Whirlpool_Cabrio_Tech_Sheet.html
If you need further assistance, let me know the results of the Diagnostics Test, and I will follow up with you.
Posted on Mar 17, 2011
Easy Flo SQ9020 stopped working - what should I check to identify what the problem is?
I am assuming you have checked the breaker that it is on? Have you tried using it at a different outlet?
Jan 10, 2015 | Easy Flo Vacuums
Ac cools then freeze up
low air flo clean evap coil
May 29, 2014 | Goldstar Heating & Cooling
2 Speed Flo-Master stuck in high speed after turning on and off the electric
Is your switch an "air switch" ... could be you have a leak in the hose that connects from the push button to the actuator that actually does the switching. Check it out.
Dec 12, 2012 | Pool & Spa
I have a flo master xp2 / 48 frame / 230V / 2.5 hp / 2 speed spa pump. I accidentally hooked switched the high and common lines when wiring the electricity. The low line was done correctly, because they...
You shorted the 230 lines at the motor terminal board. If you are certain you have reset any and all breakers feeding the spa and that the 230V is getting back to the pump motor then you blew the winding leads as you shorted the motor. While it is possible a motor shop could repair the leads it is far more likely the damage caused will cause the price to be that or more of a replacement motor.
John
Sep 21, 2010 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
The coil in the freezer is freezing up no air flo
either defrost timer, t-stat or heater is bad. either way it is worth repairing.
Feb 12, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
