Question about Refrigerators
It will not go into the auto defrost cycle - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 17, 2011
Defrost cycles
Defrost cycle usually comes on after about 7 hours. If it is happening every 30 minutes or so, the defrost timer is not working properly and your internal temperature will never have a chance to go down to zero as SOP.
When defrost cycle comes on, the compressor is automatically shut off and internal freezer temps can go up by close to 25 degrees or more. It is for this reason that commercial freezers do not have auto defrost - the latter extols a price, convenience at the price of higher average temps and less time to properly store foodstuffs in freezer.
Nov 20, 2013 | Freezers
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GMH5205XVQ_Use%20and%20Care_EN.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
How to replace a defrost heater on a ge side by side
The auto defrost cycle uses 4 components. A timer, a defrost heater, a defrost termination switch and a fusible link.
Any one of those could stop your fridge from defrosting.
The best thing to do is do a diagnostic on the defrost components to work out which component is actually faulty.
Mar 31, 2011 | Refrigerators
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
What is the difference between self defrost and cyclic defrost.
Hi, Self defrosting is auto defrost with out cycle. It work on controller leads. Cycle defrost timed defrost. It work after certain time The defrost work on evaporator
Jan 23, 2011 | Refrigerators
Our 4 year-old Whirlpool Upright Fridge/Freezer model 2FHKXXKQ03 repeatedly trips out on the defrost cycle. We live on a small island in Moreton Bay Queensland and without any Island-based technical...
check the timer maybe your Fridge it has timer to defrost or is set to auto defrost try to make set to manually defrost..or if you have manual of that item read it for guidance..
Apr 02, 2010 | Freezers
HOW TO BYPASS
If the refrigerator is not icing up it could be the defrost thermostat making the defrost cycle initiate every time the defrost timer makes defrost available. I do not recommend by-passing the defrost cycle, have the switch checked and replaced if needed.
May 26, 2009 | Frigidaire Freezers
Defrost trey and drain keeps freezing and water leaks inside
Your auto defrost cycle is not functioning.    The refrig will work for a few days and then freeze up again.   You will need to determine the cause, from a defective defrost heater, defective defrost bimetal, or Defrost timer  (mechanical or electronic control board).
Mar 14, 2009 | Whirlpool GS6SHEXNL Side by Side...
Auto defrost cycle
you can tell if it is in a defrost by listening in the freezer for a sound similar to water dripping on a hot surface. this should only be for a short time.
Nov 04, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Cooling coil in freezer compartment froze up
id say your right the unit should defrost for 30 mins of every 8 hours of compressor runnig time now that's not normal time because the thermostat cuts the unit off and on every now and then . the timer for defrost measures how long the compressor runs and it varies with how often the doors are open im sure parts of your defrost system are inoperative send me an e mail with your model number and i will help b4829@yahoo.com
May 26, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
