Question about Dba X-rite ColorMunki Photo
Why does my colormunki close down after activation? It won't allow me to profile my monitor it just closes down.
I found the instructions on: http://support.colourconfidence.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=218&nav=0,49 to solve this problem for me.
Basically, it boils down to going to your network connection manager and hitting alt+F to bring up the menu bar, then go to advanced and the advanced settings and moving your wired lan connection to be above your wireless connection. You can still connect using the wireless connection but for some reason the LAN connection needs to be listed first or the colormunki software does this.
Posted on Dec 21, 2011
GE Dishwasher Won't turn on
Door may not be fully closing for some reason.
Mar 15, 2012 | General Electric GE Profile Dishwasher 24...
How do I reset my flatron w2052tq monitor to factory settings? . I shipped my monitor to my new home and now I can't get my monitor and printer to agree on a color--I use a ColorMunki to calibrate,...
For the LG w2052tq, you can do a reset to factory settings through the OSD menu. Press Menu then go down to Setup. Press Auto/Set and go down to Factory Reset. Press Auto/Set and confirm the action. Then press Menu twice if needed to exist the menus.
Alternatively, press the Up and Down arrows together.
Remember that you can only adjust the white balance of the monitor when the incoming signal is Analog. Documentation for the monitor is available here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W2052TQ-TF&matchedModelCode=1000004018&searchEngineModelCode=W2052TQ&initialTab=documents&targetPage=support-product-profile .
I hope this helps.
Jun 24, 2011 | Computers & Internet
How to use my laptop camera?I want to take aphoto from my laptop camera in order to edit it in my face book profile!
1. open your facebook.
2. then go to your profile.
3. Then from profile page click on "Photo".
4. After clicking on "Photo" it will show three options there "Upload Photo, Take a Photo, and Create an Album.
5. Please choose Take a photo among the options by clicking it.
6. Once you on Take a Photo the Adobe Flash player settings appears.
7. From Adobe Flash player settings dialog box select or put a bullet on "Allow".
8. After clicking on "Allow" your webcam will active then hit "close" option from the dialog box so that the dialog box will disappear.
Then you can take photo from you HP laptop using your facebook.
May 30, 2011 | HP Pavilion dv6000z Notebook
My rear lift gate on 07 tahoe opens and closes its self weather the key is in the ignition or not, opens 1/2 way closes 3/4 then all the way up and all the way down, sometimes it sets off the car alarm- it...
Operation
A power open or close cycle can only be initiated from the fully closed or open positions while the vehicle is in park and the liftglass ajar switch input to the liftgate module is inactive. At any time during a power open or close cycle the operation can be reversed by pressing any of the open/close switches. The power liftgate can be switched to manual mode with the on/off switch in the overhead console and during manual operation the power latch will still operate. During power liftgate operation the liftgate module continuously monitors the liftgate position and load profile. The position is calculated from hall effect sensor counts and the electrical load of the gear motor is used to determine physical resistance to the liftgate. Both of these profiles must be learned before the liftgate can operate properly and relearned any time most liftgate components are serviced.
Object Obstruction Detection
The liftgate control module continuously monitors power liftgate operation and calculates its location and direction of travel using 2 hall effect sensors that are part of the gear motor assembly. The hall effect sensors are 3 wire sensors and are supplied with a 5 volt power circuit, ground and signal circuits from the liftgate control module. The hall effect sensor signal circuits are referenced from battery voltage within the liftgate control module and pulsed low by the hall effect sensors.
The power liftgate system uses a secondary object detection method which consists of object sensors fixed to both sides of the liftgate near the seal area. The object sensors consist of an internal fixed resistor and normally open switch contacts which when closed will bypass the resistor. The signal circuit is supplied 5 volts through a resistor and monitored within the liftgate control module, and during normal power liftgate operation the signal circuit should remain a fixed value. When an object presses one of the sensors the contacts close and the resistor is bypassed causing the signal circuit voltage at the module to go low.
Gear Motor Assembly
The liftgate motor is a bi-directional motor and open or close operation is the result of the direction of the motor rotation. The liftgate module controls the liftgate motor through the control circuits by suppling power and ground in the appropriate polarity. The motor control circuits are monitored by the liftgate module prior to activation for a high or low condition and during motor operation for any irregular current flow conditions.
The liftgate motor clutch engages or disengages the liftgate motor to the liftgate drive gear and is the component that determines power or manual operation. When the liftgate module supplies power to the clutch control circuit the clutch coil is energized and the liftgate motor is engaged to the liftgate drive gear so that power operation can occur. The liftgate module monitors the clutch control circuit at all times for a short high while in an inactive state or a short low or insufficient current flow while in an active state.
The full open switch is part of the gear motor assembly and will close and become active when the liftgate reaches the full open position. The full open switch signal circuit is supplied battery voltage through a resistor and monitored within the liftgate module. The liftgate provides a low reference circuit and when the switch contacts close the signal circuit goes low and the liftgate module determines the switch to be active.
DTC B153A 00: Liftgate Latch Switch Signal Circuit
DTC B153A 08: Liftgate Latch Switch Signal Circuit Signal Invalid
When calibrating the liftgate position, the liftgate module (LGM) is placed in a functional state to learn the liftgate travel limits. DTC B1019 00 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the travel limits are learned by the liftgate module, the LGM will exit calibration mode. If the LGM does not exit learn mode, DTC B1019 00 will remain current and indicate a fault.
DTC B153B 02: Liftgate Open Switch Signal Circuit Short to Ground
DTC B153B 05: Liftgate Open Switch Signal Circuit Short to Short to Battery or Open
DTC B153E 02: Liftgate Position Sensor Signal Circuit Short to Ground
DTC B153E 05: Liftgate Position Sensor Signal Circuit Short to Battery or Open
DTC B153E 08: Liftgate Position Sensor Signal Circuit Signal Invalid
Your best bet , take it to the dealer .
Aug 08, 2017 | Chevrolet Tahoe Cars & Trucks
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When I close the phone the (ring) volume returnes
hi sunshine,
just set the same profile as you have on the opened one as to the closed one, this will not allow your phone to automatically select profile like on handsfree or not.
regards
Jul 08, 2009 | LG Shine KE970 Cellular Phone
Computer very slow for all applications
Okay re: 10.5.6. Try these: 1. Restart with Command + Option + letter "P" + letter "R" depressed after the startup "bong". This will zap the PRAM and is the first thing to do. When this finishes allow the machine to restart and see if the problem still exists. If not, go to the next step. 2. Using the application, "Disk Utility" found in the Utilities Folder, choose "Repair Permissions". When this finishes, restart the machine and see if the problem still exists. 3. Using the application, "Activity Monitor" found in the Utilities Folder you will see all opened applications and how much memory they are using. This will tell you which application is hogging the processor. Try forcing it closed which is an option in Activity Monitor and see if the problem goes away . 4. Keep me updated.
Mar 14, 2009 | Apple Mac 10.5.1 Desktop
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Dba X-rite ColorMunki Photo   Logo
994 people viewed this question
Top Dba Computers & Internet Experts
richie46
Rose li
Rose li
jewicebosell
jewicebosell
Are you a Dba Computer and Internet Expert? Answer questions, earn points and help others
