Question about Zanussi Washing Machines
Zanussi ZWF 1427 W. Some programmes just don't work. Some do. Anyone know about this?
  • 96 Answers
SOURCE: zanussi zwf 1432 w washing machine
Normally when the light above the Start button is flashing it means that the machine is in Pause mode. Then you have to hit the button again to get it to start. If it still doesn't work try the Reset button also.
Posted on Mar 07, 2008
  • 4 Answers
SOURCE: zanussi zwf 1415w become very noisy when it is running all time?
you have to call a technician to check the drum bearing
Posted on Jun 04, 2008
abhishek33
  • 1239 Answers
SOURCE: zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Posted on Sep 12, 2008
rylee_smith
  • 8619 Answers
SOURCE: zanussi zwf 16000w
Hi! It seems to be a common error code on some Zanussi models. This error code is caused due to an illogical set of sensing conditions from its connected sensors and wiring. It happen when wires become badly contacting or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutation and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts. To perform this you need to follow the following procedure: Unplug the machine. Take the top off the machine and on the right hand side of the machine, you will see a set of 4 blue wires that go from the electronics module to the front display unit. Take this plug off, clean with wd40, or silicone contact cleaner, then dry, replace, then try again. If it is very badly corroded or pitted, you may have to replace that part of the wiring and socket. If the problem is not as stated above then the wiring to/from various other sensors could be damaged or the control board could be faulty. It is worth checking around other plugs and sockets, re-seating each one in turn, that lead to the control board. Pulling off and plugging back on (Re-seating) the plugs and sockets has the effect of cleaning the contacts, and may fix certain intermittent faults like this. Obviously check for any plugs/sockets that appear burnt, corroded, or discolored compared with the others, and clean the contacts with emery or a needle file. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 06, 2009
SOURCE: My Zanussi ZWF 1221 W will not rinse. Any ideas?
my zanuzzi 1500 will not rinse
Posted on Aug 22, 2009
How do I set spin only for Zanussi Lindo100 ZWF 71263W/71463W washing machine?
Spin
With this option you can change the default spin speed.
The indicator of the set speed comes on. Additional spin options:
No Spin
• Set this option to deactivate all spin phases.
Only the drain phase is available.
• The related indicator comes on.
• Set this option for very delicate fabrics.
• The rinses phase uses more water for some
washing programmes.
Rinse Hold
• Set this option to prevent the laundry creases.
• There is a water in the drum when the programme is completed.
• The drum turns regularly to prevent the laundry creases.
• The door stays locked. You must drain the
water to unlock the door.
untitled-pqbhbvgkecedzsp304arfp23-2-0.jpg Dado
Jan 18, 2018 | Zanussi Washing Machines
Error code E 31 on a zanussi zwf 1431 front loader machine may not be water in. water feed and filter ok
The code E31 relates to a problem normally with the pressure switch,heater or maybe the Programmer.The heating element may even check out with a test meter but it can be an earth fault and normally just replacing this part cures the fault.If you are not electrically competant it would be worth getting it checked.
Hope I have helped.
Apr 25, 2010 | Zanussi ZWF1430W Front Load Washer
My problem is the machine makes a noise as if a piece of cardboard is rubbing at one particular point each revolution of the drum it has now become quite loud on my zanussi zwf 1632 w can anyone help ?
I may just be lucky or it might just be temporary but the fault has cleared on my zanussi zwf 1632 w. washing machine thanks for the offers of help if needed in future i will certainly contact FixYa."Bill 34"
Sep 19, 2009 | Washing Machines
Washing machine will not start
I don't think this is a GE model #, but any who, if you hear a humming <water valve sol> the product valve is not getting water to it, first, don' laugh, make sure both plumming valves are on..
If they are off and no one knows how they got turned off, it falls under the old "****-happens" deal !
May 20, 2009 | Washing Machines
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Zanssi washing machine ZWF 1221 W will not spin
Do you realise there is a law I understand that says for 6 yrs the goods should be fit for the purpose you bought them for. Look at this "your rights " & go tackle the store you bought the machine from.
http://www.guardian.co.uk/money/2006/jun/01/yourrights.legal4
Jun 21, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
