Question about Desa International CGCFTP Compact Heater
How can I adjust the flame? I have the CGCFTP and one side of the flame is higher (alot) than the other side. It's burning the top of the metal insert.
    Brigadier General:
  • 4,736 Answers
Normally, you can raise and lower the flame height, with the Control Knob (Wider the white stripe the higher the flames. Narrower the stripe, the lower the flames). But, I don't think that's your problem. From your description, it sounds like the burner may be clogged or there is a air shutter control problem on the open end of the burner. This controls the air to gas ratio. Also, depending on the age of this Compact Classic Firebox and whether or not annual maintenance was preformed regularly, the burner may be shot entirely. Since DESA International, who made the Comfort Glow line for Lowe's, went out of business in 1999, we know the heater is at least 2 years old, minimum. Although, I suspect yours is an older model, based on the Model Number you provided. If you feel comfortable troubleshooting it yourself, I have provided a link to your Owner's Manual, in case you have misplaced yours. You can down load and print it for future, as well as for any parts you may need.
http://www.desatech.com/manuals/Fireplaces/model_CGCFTP_manual_111044-01L.PDF
If you don't feel comfortable repairing it yourself, contact your propane provider. As most propane providers also do service and repair for this type of Vent-free Gas Fireplace.
Hope this helped to steer you in the right direction.
Posted on Mar 17, 2011
  • Rols1 Dec 15, 2011
    I was having the same problem. After reading your response we gave it a very good cleaning with a vacuum and canned air. AMAZING. There are air orifices on the right end of the burner which you cannot see. Use a vacuum wand to clean them very well. This may need several good cleanings. Also there is an air shutter on the left end you cannot see. Use a vacuum wand here as well. By getting both of these very clean the tall yellow has receded. The flame is now at it's original height and the blue is back. Thanks for the hint.
Oven flame is yellow
There is an adjustment on the burner assuming that the top side burners are ok. Getting to that adjustment may be a pain, so look for a screw on the metal sleeve on the end that the gas line connects to. this sleeve controls the amount of air that mixes with the gas to produce a hot flame. Do not let this go, because the amount of carbon monoxide the oven produces now can be lethal.
Feb 21, 2014 | Ovens
New smeg gas cook top. flames burn with yellow top
There has to be a small screw close to where the burners are located and all you need to do is turn clockwise half a turn at a time (have the flame/burner on), to adjust the flame . Good luck
Nov 03, 2013 | Kenmore 63942 Dryer
Why is the right side of the heater flame higher and hotter then the left side
Combustion needs air mix in the correct proportion to burn efficiently-also gas supply may be stronger on the outlet side of burner causing an imbalance-chech for obstruction in either area-cheers Denny
Oct 11, 2013 | Vanguard International Blue Flame - Large...
How to adjust the flame on a hotpoint oven
theres no flame adjustment as such,if the oven was on natural gas(in town) and has been changed to propane type gas(in the country) and the orfice spud has not been adjusted the flame will be about 3 times higher than normal,you need to turn this spud down onto the top of the orfice
Oct 23, 2012 | Hotpoint Ovens
Fireplace will start but shuts off in about 30 seconds
Here's a few things to look for. After you light the pilot and turn on the burner, look at the pilot flame. Is it still a strong blue flame and it is still heating the thermocouple? If the pilot flame is a lazy yellow, it may not be able to keep a good enough flame on the thermocouple to keep it hot. The solution? Turn it all off and let it cool down. Take a can of compressed air, like you use to clean computer keyboards, and using the attached straw, blow out the dust or spider web that's partially blocking your pilot orifice. Where the pilot flame is usually lit, blow right down that flange, as well as through the air hole that is on the side of the pilot assembly. If you do it right, the pilot flame should be a nice and strong blue color. Another thought. Is this a vented or unvented fireplace? If it's vented, make sure it has the oxygen it needs to burn by checking for blocked vents or opening a closed fireplace fume above it.
Douglas
Nov 19, 2010 | Desa International CGCFTP Compact Heater
I replaced the wick and i can not get a full flame and i have it adjusted all the way to the top
The wick needs to be cut like a tongue, or at least cut the corners off and try to make it round this gives it a better flame if it's left square it won't burn off the ends so the flame will be flat at the top and will not burn properly.
Feb 11, 2010 | Dyna-Glo Heating & Cooling
KitchenAid Stovetop with grill and griddle - KGCP484KSS0
hi im gerbee, try to clean the sensor valve by using a scott brite, the sensor place in the side wen the flame is on like a gold metal, 2nd try to adjust the flame control by using a plat or + screw,u see it at the gas control knot on top the small screw.adjust to high flame is touch the sensor valve.sory for my english.tnx gerbee i hope i help u
Nov 30, 2008 | KitchenAid Architect KGCP484KSS Gas...
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
Jul 18, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Heating & Cooling Logo
311 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
