Question about Dymo LabelWriter Thermal Printer
The printer jammed and now there is sticker paper stuck inside near the roller. it is hard to see and can NOT be pried out. it is jamming the system and will not accept the roll. how do i clean it out? its a tiny strip of sticker that is adhered to a part of the machine deep down.
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
Joed911
  • 4338 Answers
SOURCE: We have a dymo labewriter
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
https://dymo.custhelp.com/app/answers/detail/a_id/278/session/L2F2LzEvc2lkL2ZVOGZXRmlr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 28, 2010
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
    I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
    Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
    My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
    This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
    A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
    Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
    Mar 28, 2010 | Office Equipment & Supplies
    The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
    The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
    Nov 17, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
    HP F4280 All in one Printer. Feed jammed (AVERY 8376 Ink Jet Business Cards); printer made noises, finally stopped; pulled paper backwards out of printer. Turned the printer on and the cartridges bang...
    Well it's likely two cause in your case -
    1.- It might be a misplaced actuator, check for instructions at:
    http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=58057&dl...
    2.- Check the power supply and its cable. It might be at the end of its life. Ideally, you should check the power supply under load at its limit. You may use a resistor rated for the load. It will be HOT, be careful. If you don't have it, might be more cumbersome, but you can use the printer as load, and make a test connector that allow you access to voltage terminals.
    Good Luck!!
    Thanks
    Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
    My printer says there is a paper jam, but when I look there is no paper jam. What can i do?
    I had a printer that kept giving me a paper jam error. Nothing visually was there though. I then opened up printer, basically took the whole thing apart bit by bit then found a tiny screw loose just laying stuck between print rollers. You can t see this when it was together. It was the work of my 2 year old dropped screw in there. I put together and worked like new. There could be some small object inside near rollers or some where inside your printer. Usually the paper jam means something is jammed in printer. If you dont want to open, which i preffered not to do but i did because i was going to trash my printer, you can call manufacture and see what options they can give you. Some will take it back if you upgrade to another printer, but you will have to pay some extra money.
    Aug 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
    Paper jam check drawer two t640 printer
    Hello there,
    If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
    Merry Christmas!
    Aug 20, 2008 | Lexmark T640 Laser Printer
    Paper Jam
    i did exactly as iamzwalrus said and it fixed.go with that if nothing eles works.
    Apr 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Error 13-jam paper HP Laser 4+
    HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
    Apr 02, 2008 | HP LaserJet 4 plus Printer
    Paper jam in tray 2
    the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
    Sep 05, 2007 | Office Equipment & Supplies
    Dymo LabelWriter Thermal Printer Logo
    212 people viewed this question
    Top Dymo Office Equipment & Supplies Experts
    Jax Planet
    Jax Planet
    jdthefixer
    Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
