Question about Motorola Computers & Internet
My on line light has started flashing on my modem how do you get it to stop so you can get on line
  • 604 Answers
Unplug the modem from its power source for at least 30 secongs, plug it back in and wait a few mintues. also, depending on which light you are talking about, one of the lights will always be flashing as it is indicating data flow in and out of the device.
Posted on Mar 17, 2011
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
Power went out and modem light start flashing
Pull the power line from the modem, for atleast 15 seconds, plug it back in. (Additionally, try pulling all wires from the back and replacing them and ensure the jack is finger tight) If it doesn't return to its normal operation then most likely it suffered from a surge and fried a circuit or two inside of it, at that point take it back into your provider and get it replaced, most providers trade modems out for free.
Mar 15, 2014 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
When i reset my modem it goes through the normal start up process but when it is trying to connect online the lights start flashing.(receive &send ) lights flash.
The light pattern you have described shows that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 31, 2010 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
Internet lights flashes then stops then flashes
its ok if the internet light on your modem is flashing. as long as its not off.
Aug 28, 2008 | Westell Wirespeed LiteLine 6100...
2Wire-3700 dsl red light blinking after a thunderstorm
If you are att customer, you will be charged $60 only if there is problem inside your premises, otherwise they wont charge you.
Is there any phone connected with your DSL line? if so is it working? if its not working, contact customer support and tell them its not working
If the phone is working, you have to check the connections between the phone line to the modem. As the DSL light is blinking red, its the problem with line and not the modem.
Take care
Jun 07, 2008 | 2wire (1000-000057-000) Modem
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
"fail: Test ADSL Line Sync" per AT&T Tech Readout
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Nov 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
391 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
