Question about Dishwashers
Dishwasher seems to be blocked all water not pumped out cleaned filter can't find blockage
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 18, 2011
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
Why is water left in the machine after cycle
Most dishwashers leave some water at the base at end of cycle.
The problem is there if a large quantity of water is left when the cycle is complete. The most common is blocked filters in the pump sump. If this is clean then the next problem could be outlet hose or the kitchen sink waste pipe. Make sure the kitchen side is clear. If all this is ok then the blockage could in the pump itself. It will look similar to this item.
Hoover Drain Pump
Aug 06, 2014 | Hoover HED661280 Dishwasher
Whirlpool 7540 start light flashs 4 times
The #4 error code on your dishwasher says it's a drainage error and that the computer didn't detect that all the water drained out of the machine. Sometimes that can be caused by a blocked filter on the pump, a blockage in the drain hose or a water level switch failure...also it can be just a electronic anomalie and the board can be reset then the dishwasher will work as normal. Or of course it could be because the filter is clogged and needs to be cleaned so water will flow through it and drain out.
I have written tips both covering how to clean the pump filter and resetting the control board,refer to them and see if they will resolve your dishwasher troubles.
TIP FOR CLEARING THE ERROR CODES FROM THE BOARD
http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
TIP TO CLEAN THE PUMP FILTER
http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 28, 2011 | Whirlpool Dishwashers
SMU2046UC: waste water won't empty. Wash cycle works like it should but waste water remains in the bottom of the dishwasher. Sounds like pump is humming and there don't seem to be any clogs in the system??
Most likely a blocked pump. You should be able to access the pump from the base of the unit under your filters. Remove the cover and rotate the pump impeller to free blockage then start any prog to check if pump is working,if OK reassemble, if not replace pump
Oct 23, 2010 | Bosch Dishwashers
Water remains in dishwasher after cycle is done !
The pump out may be blocked.A lot of people dont clean out the filters inside the dishwasher causing blockage,also maybe piece of debri could be jamming the pump impellor,or hose connection under sink is blocked.
May 28, 2010 | Dishwashers
Water is not draining from the bottom. screen looks dirty, how to clean?
Take out the filter cup screw anticlockwise and lift the filter assembly will lift out also. You may find the blockage there. If you are careful you can take the drain pump cover off from the inside and find a blocked impellor usually broken glass or crockery.
Feb 24, 2010 | Asko D1776 Built-in Dishwasher
Hi, hoover hed6612-80 when the door is opened the
The problem is most likely that the drain is blocked. Remove the lower front panel on the dishwasher. You will see the drain hose connected to a small pump close to the floor. disconnect the hose and remove the pump. There will be some water so be prepared with some paper towels, or rags. Remove the small pump so you can visually inspect it on the inside, remove any debris you find. If there is no debris there go under the kitchen sink and disconnect the other end of the dishwasher hose. you can then remove the entire hose to inspect it for a blockage. If no blockage in the hose, you must then check the path of the drain water through the garbage disposal [if you have one] and then the trap.
Oct 01, 2009 | Dishwashers
WATER WILL NOT DRAIN OUT
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.hope this helps
Jun 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Won't start
It sounds like you have a food blockage or some blockage between where the water fills up and where it goes into the pump you need to take out the water wand (the rotating thing with water coming out) only the bottom one. You need to unscrew the water wand and make sure nothing is blocking in there.
If not then check your filter which should be next to the water wand remove it and then clean it and make sure nothing in in there to block water getting through.
If you have any questions please dont hesitate to ask
May 27, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
Dishwasher fdw80
The clog is going to be in the water pump.Remove both pump hoses and look for the blockage inside the pump and also the two pump hoses.
May 19, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
